如果这些限超过了,就要对分析中的误差来源进行分析和纠正,而且所有后来的分析,包括最后的依据规格进行的验证性分析,也都需要重复进行。
什么限?应该在上下文里面吧
xnwang 发表:内容主要是对实验室内部分析的重复性和精确性进行例行监控
If these limits are exceeded, the sources of error in
the analysis should be determined, corrected, and all analyses
subsequent to and including the last duplicate analysis confirmed
to be within the compliance specifications should be repeated.
