The following AATCC standards have been developed, revised, or reaffirmed since publication of the 2019 volume of the Technical Manual. In accordance with AATCC M13, Rules of Procedure for AATCC Test Method and Technology Committees, all technical changes are unanimously approved by the responsible research committee and the Technical Committee on Research (TCR) before publication.
Test Method for Seam Smoothness in Fabrics after Home Laundering. Revised to clarify use of standard detergent WITH optical brightener and add references for alternate laundering procedures.
Test Method for Crease Retention in Fabrics after Home Laundering. Revised to clarify use of standard detergent WITH optical brightener and add references for alternate laundering procedures.
03AATCC TM89-2019
棉丝光测试方法。修订增加了使用AATCC摩擦布作为未丝光棉参考织物的选项。
Test Method for Mercerization in Cotton. Revised to add the option of using AATCC crocking cloth as an unmercerized cotton reference fabric.
04AATCC TM92-2019
残留氯强力损失:单试样法。修订使格式与AATCC风格一致。
Test Method for Chlorine, Retained, Tensile Loss: Single Sample Method. Revised to align format with AATCC style.
05AATCC TM93-2019
织物的耐磨性能:加速法。修订以明确棉织物的结构。
AATCC TM93-2019, Test Method for Abrasion Resistance of Fabrics: Accelerotor Method. Revised to clarify construction for cotton fabric.
06AATCC-TM97-2019
纺织品中的可萃取物含量测试方法。修订使格式与AATCC风格一致。
Test Method for Extractable Content of Textiles. Revised to align format with AATCC style.
07AATCC TM100-2019
纺织材料抗菌整理剂的评价。修订去除了导致最终使用者困惑的问题。通过明确界定参数来减少歧义。
Test Method for Antibacterial Finishes on Textile Materials: Assessment of. Revised to remove several issues that have led to considerable confusion among end users. Reduced ambiguity by specifically defining parameters.
08AATCC TM101-2019
过氧化氢漂白色牢度测试方法。修订使格式与AATCC风格一致。
Test Method for Colorfastness to Bleaching with Hydrogen Peroxide. Revised to align format with AATCC style.
09AATCC TM103-2019
退浆中使用的细菌α-淀粉酶的分析。修订使格式与AATCC风格一致。
Test Method for Bacterial AlphaAmylase Enzymes used in Desizing, Assay of. Revised to align format with AATCC style.
Test Method for Colorfastness to Crocking: Rotary Vertical Crockmeter. Revised to align with AATCC TM8 and address industry questions. Precision data added. Editorially revised to correct downward force of rubbing finger.
11AATCC TM 117-2019
耐干热色牢度(热压除外)。说明性修订,同时使格式与AATCC风格一致。
Test Method for Colorfastness to Heat: Dry (Excluding Pressing). Revised for clarification and to align format with AATCC style.
12AATCC TM119-2019
平磨色牢度测试方法(霜白):金属丝网法。说明性修订(题目变更),同时使格式与AATCC风格一致。
Test Method for Colorfastness to Flat Abrasion (Frosting): Screen Wire. Revised (with title change) for clarification and to align format with AATCC style.
13AATCC TM120-2019
平磨色牢度测试方法(霜白):金刚砂法。说明性修订(题目变更),同时使格式与AATCC风格一致。
Test Method for Colorfastness to Flat Abrasion (Frosting): Emery. Revised (with title change) for clarification and alignment of format with AATCC style.
14AATCC TM122-2019
地毯沾污测试方法:实地沾污法。修定以纠正合成污物土配方包括黑色氧化铁(代替红色)。
Test Method for Carpet Soiling: Service Soiling. Revised to correct synthetic soil formulation to include black iron oxide (in place of red).
Test Method for Smoothness Appearance of Fabrics after Home Laundering. Revised to clarify use of standard detergent WITH optical brightener and add references for alternate laundering procedures.
16AATCC TM130-2018t
去污性测试方法:油渍清除法。修订以定义标准的洗涤条件。
Test Method for Soil Release: Oily Stain Release. Revised to define standard laundering conditions.
17AATCC TM131-2019
蒸汽褶裥色牢度测试方法。修订使格式与AATCC风格一致。
Test Method for Colorfastness to Steam Pleating. Revised to align format with AATCC style.
18AATCC TM134-2019
地毯的静电倾向测试方法。修订增加测试过程中相对湿度允差。
Test Method for Electrostatic Propensity of Carpets. Revised to increase tolerance for relative humidity during testing.
Test Method for Dimensional Changes of Fabrics after Home Laundering. Revised to clarify use of standard detergent WITH optical brightener and add references for alternate laundering procedures.
20AATCC TM141-2019
腈纶用碱性染料的配伍性。修订以阐明AATCC染料有效性,同时使格式与AATCC风格一致。
Test Method for Compatibility of Basic Dyes for Acrylic Fibers. Revised to clarify availability of dyes from AATCC and align with prescribed AATCC style.
Test Method for Appearance of Apparel and Other Textile End Products after Home Laundering. Revised to clarify use of standard detergent WITH optical brightener and add references for alternate laundering procedures.
Test Method for Dimensional Changes of Garments after Home Laundering. Revised to clarify use of standard detergent WITH optical brightener and add references for alternate laundering procedures.
23AATCC TM171-2019
地毯清洁测试方法:热水萃取法。修订包括增加清理真空缝隙的建议以防止聚集。
Test Method for Carpets: Cleaning of; Hot Water Extraction. Revised to include recommendation for clearing vacuum slot to prevent banding.
24AATCC TM175-2013e2
绒毛地毯耐沾污性测试方法。重审和编辑性修订。
Test Method for Stain Resistance: Pile Floor Coverings. Reaffirmed with editorial changes.
25AATCC TM179-2019
经家庭洗涤后的织物纬斜。修订以定义标准的洗涤条件。
Test Method for Skew Change in Fabrics After Home Laundering. Revised to define standard laundering conditions.
26AATCC TM204-2019
纺织品透湿性能测试方法。修订,在气流测试物质清单中增加风速计。
Test Method for Water Vapor Transmission of Textiles. Revised to add an anemometer to the materials list for measuring airflow.
27AATCC TM205-2016e
地毯:液体渗透性试验。重审和编辑性修订。
Test Method for Carpet: Liquid Penetration by Spillage. Reaffirmed with editorial changes.
28AATCC TM207-2019
成衣经家庭洗涤前后扭曲性能。修订以定义标准的洗涤条件。
Test Method for Seam Twist in Garments Before and After Home Laundering. Revised to define standard laundering conditions.
29AATCC TM208-2017e
抗水性耐静水压(隔板法)。重审和编辑性修订。
Test Method for Water Resistance: Hydrostatic Pressure Test Using a Restraint. Reaffirmed with editorial changes.
Test Method for pH and Total Alkali in Wet Processed Textiles: Combined. New test that provides a viable means for checking both pH and alkalinity in one method using the same piece of fabric.
31AATCC TM210-2019
多种环境暴露前后电阻测试方法。新方法,为电子纺织材料的常规测试提供指导。
Test Method for Electrical Resistance Before & After Various Exposure Conditions. New method that provides guidance for performing common tests on e-textile materials.
32AATCC EP1-2018
变色用灰卡评价程序。修订,为了清晰和一致。
Evaluation Procedure for Gray Scale for Color Change. Revised for clarity and consistency.
33AATCC EP2-2018
沾色用灰卡评价程序。修订,为了清晰和一致。
Evaluation Procedure for Gray Scale for Staining. Revised for clarity and consistency.
Evaluation Procedure for Electrical Resistance of Electronically Integrated Textiles. New procedure for initial evaluation of electrical resistance of electronically integrated textiles and/or for evaluation of these same textiles after some treatment (e.g., laundering, stretch, etc.). Editorially revised to correct materials source.
35AATCC M11-2019
AATCC标准术语表。修订以反映参考标准中添加或修订的术语和定义。
Glossary of AATCC Standard Terminology. Revised to reflect terms and definitions added or revised in referenced standards.
36RA100
全球可持续性测试方法。修订标题和范围,以反映从技术到测试方法委员会的变化。
Global Sustainability Test Methods. Title and scope revised to reflect conversion from technology to test method committee.
Designations and titles. All standards not technically revised were editorially revised to reflect a new format for designations and titles. Designation includes year of last technical revision, with year of last subsequent reaffirmation in parentheses, if applicable. A small letter “e” indicates editorial changes and a small letter “t” indicates additional technical changes in the same year.
