启航2021
第2楼2021/02/23
字面含义,就是成分相互作用,成分间相互作用。
可以参考下面论文Evaluation of the content - containing interaction in cosmetic products using gas chromatography-mass spectrometry和Optimization of the method of the content-containing interaction evaluation for cosmetic products by gas chromatography - mass spectrometry
symmacros
第4楼2021/02/24
symmacros
第6楼2021/02/24
谢谢,有道理。
