氯苯类方法验证
气体检测
  • 仪器条件仪器gc 5890F编号WHBP-E-06
    毛细管柱DB-170130m*0.25mm*0.25μm
    柱前压0.15MPa柱流量恒流2.0ml/min
    检测器FID
    进样口260℃隔垫吹扫3.0mi/min
    柱箱升温方式程序升温
    升温梯度50℃(5min)--8℃/min--250℃(1min)
    检测器300℃尾吹30nl/min
    进样量1.0μL
    校准曲线12345678910
    单位浓度/目标化合物氯苯2-氯甲苯3-氯甲苯4-氯甲苯1,3-二氯苯1,4-二氯苯1,2-二氯苯1,3,5-三氯苯1,2,4-三氯苯1,2,3-三氯苯
    mg/L
    2.0 1932214820302044157616201486134811971335
    5.0 4710538351595328391738964053338532253314
    10.0 95521006196709875752682157239636162806052
    20.0 18758210402062220771158861556715578135491251712975
    100.0 95847107724103612104823789827826478941680716419065843
    校准曲线Y=959.2X-123.3Y=1080X-312.9Y=1038X-230.2Y=1050X-200.4Y=790.8X-91.08Y=781.6X+96.23Y=791.4X-224.4Y=682.1X-145.8Y=642.9X-133.6Y=659.9X-177.9
    r0.999990.999970.999970.999980.999980.999980.999960.999970.999980.99996
    1检出限无组织标况采样体积30L,解析液体积1.00ml,向7只同批次空白活性炭吸附管中加入1.0μg标准品,后采集清洁空气30L,用胶帽密封两端,
    将A,B两段分别转移至5ml具塞玻璃试管中,各加入1.0ml色谱纯二硫化碳,于超声清洗仪中超声解吸1min,静置30min,取1.0μL上机测试。
    12345678910
    测定次数氯苯2-氯甲苯3-氯甲苯4-氯甲苯1,3-二氯苯1,4-二氯苯1,2-二氯苯1,3,5-三氯苯1,2,4-三氯苯1,2,3-三氯苯
    11.0516 1.0100 0.9547 0.9298 0.9928 0.9610 0.9496 0.9308 0.9470 1.0741
    21.0263 1.0101 0.9608 0.9281 0.9771 1.0017 0.9495 0.9470 0.9304 1.0419
    31.0753 1.0391 0.9979 1.0018 1.0115 0.9737 0.9976 1.0160 0.9596 0.9761
    41.0016 1.0391 0.9576 0.9573 1.0034 1.0017 0.9624 1.0185 0.9602 1.0069
    51.0183 1.0409 1.0212 1.0018 1.0115 1.0962 0.9976 0.9798 0.9959 1.0305
    60.9787 1.0239 0.9647 0.9846 0.9657 1.0539 0.9882 1.0275 1.0106 0.9722
    71.0160 0.9883 0.9995 0.9573 0.9877 1.0017 0.9976 0.9886 1.0070 0.9924
    平均值1.0240 1.0216 0.9795 0.9658 0.9928 1.0128 0.9775 0.9869 0.9730 1.0134
    标准偏差0.0318 0.0199 0.0263 0.0311 0.0174 0.0470 0.0228 0.0372 0.0314 0.0373
    t值3.1433.1433.1433.1433.1433.1433.1433.1433.1433.143
    检出限μg/ml0.0998 0.0624 0.0826 0.0978 0.0547 0.1476 0.0716 0.1168 0.0988 0.1173
    无组织检出限
    (采样体积30L,
    解吸液体积1.0ml)
    0.0033 0.0021 0.0028 0.0033 0.0018 0.0049 0.0024 0.0039 0.0033 0.0039
    无组织方法检出限(采样体积30L,
    解吸液体积1.0ml)
    0.0080.0090.0080.0080.0080.0080.010.0080.0070.008
    无组织测定下限
    (采样体积30L,
    解吸液体积1.0ml)
    0.013 0.008 0.011 0.013 0.007 0.020 0.010 0.016 0.013 0.016
    无组织方法测定下限(采样体积30L,
    解吸液体积1.0ml)
    0.032 0.036 0.032 0.032 0.032 0.032 0.040 0.032 0.028 0.032
    结果判定符合符合符合符合符合符合符合符合符合符合
    有组织检出限
    (采样体积10L,
    解吸液体积2.00ml)
    0.020 0.012 0.017 0.020 0.011 0.030 0.014 0.023 0.020 0.023
    有组织方法检出限
    (采样体积10L,
    解吸液体积2.00ml)
    0.030.030.030.030.030.030.040.030.020.03
    有组织测定下限(采样体积10L,
    解吸液体积2.00ml)
    0.08 0.05 0.07 0.08 0.04 0.12 0.06 0.09 0.08 0.09
    有组织方法测定下限(采样体积10L,
    解吸液体积2.00ml)
    0.12 0.12 0.12 0.12 0.12 0.12 0.16 0.12 0.08 0.12
    2.精密度无组织标况采样体积30L,解析液体积1.00ml,向6只同批次空白活性炭吸附管中分别加入4.0μg、30.0μg、75.0μg标准品,后采集清洁空气30L,用胶帽密封两端,即得0.13mg/m3、1.00mg/m3、2.50mg/m3样品
    将A,B两段分别转移至5ml具塞玻璃试管中,各加入1.0ml色谱纯二硫化碳,于超声清洗仪中超声解吸1min,静置30min,取1.0μL上机测试,计算6次测定平均值,标准偏差和相对标准偏差
    低浓度
    4ppm0.13mg/m312345678910
    13.93444.02363.84153.93033.9684.00983.9873.83553.91494.073
    23.84553.92044.08063.91063.82053.92023.85613.86074.02964.0192
    33.93393.97843.81493.95383.88233.92753.96313.89593.89744.0352
    43.84573.92043.99413.96453.94273.95953.9183.87744.02954.0083
    53.89573.99163.84133.96823.84293.95753.91793.89593.86463.9745
    63.92354.04063.8780 3.94643.81833.96873.96713.89594.01823.9179
    平均值3.8965 3.9792 3.9084 3.9456 3.8791 3.9572 3.9349 3.8769 3.9590 4.0047
    标准偏差0.0418 0.0506 0.1055 0.0219 0.0639 0.0321 0.0476 0.0247 0.0750 0.0534
    相对标准偏差1.07%1.27%2.70%0.55%1.65%0.81%1.21%0.64%1.89%1.33%
    精密度中浓度1.00mg/m3
    30ppm12345678910
    130.550629.957329.978729.078829.682829.555929.083130.160830.701830.6368
    229.623429.778430.455829.254529.524629.061629.132729.641130.284430.2963
    329.5129.604729.965129.042329.471829.292728.95128.974330.282329.981
    429.014429.498230.21229.164829.897328.886629.132729.406330.522231.1708
    529.643430.208530.350829.217129.897329.061629.465930.222730.658830.5143
    629.993230.279430.5591 29.705129.940329.654230.109329.684230.915331.233
    平均值29.7225 29.8878 30.2536 29.2438 29.7357 29.2521 29.3125 29.6816 30.5608 30.6387
    标准偏差0.5141 0.3178 0.2467 0.2399 0.2055 0.3039 0.4258 0.4691 0.2492 0.4902
    相对标准偏差1.73%1.06%0.82%0.82%0.69%1.04%1.45%1.58%0.82%1.60%
    精密度高浓度2.50mg/m3
    75ppm12345678910
    167.83467.988468.639367.382668.133669.545167.819368.222569.888368.9351
    268.343368.247269.915767.923168.348569.905268.060169.080270.266869.143
    368.390769.044669.973668.630368.518369.905268.393468.960670.676469.0555
    468.523868.49970.488670.941269.632670.093769.414769.186370.622270.5871
    569.193969.291469.455269.036969.632670.836270.716268.739572.080869.2237
    668.116469.531970.3168 69.434569.392570.836268.343769.069971.4560 70.6663
    平均值68.4004 68.7671 69.7982 68.8914 68.9430 70.1869 68.7912 68.8765 70.8318 69.6018
    标准偏差0.4582 0.6141 0.6709 1.2490 0.6844 0.5334 1.0892 0.3545 0.8034 0.8000
    相对标准偏差0.67%0.89%0.96%1.81%0.99%0.76%1.58%0.51%1.13%1.15%
    3.准确度无组织标况采样体积30L,解析液体积1.00ml,向6只同批次空白活性炭吸附管中分别加入7.50μg、60.0μg、90.0μg标准品,后采集清洁空气30L,用胶帽密封两端,即得0.25mg/m3、2.00mg/m3、3.00mg/m3样品
    将A,B两段分别转移至5ml具塞玻璃试管中,各加入1.0ml色谱纯二硫化碳,于超声清洗仪中超声解吸1min,静置30min,取1.0μL上机测试,计算6次测定平均值,标准偏差和相对标准偏差和加标回收率
    低浓度
    准确度低浓度2.50mg/m3
    7.5ppm12345678910
    16.6917.37297.0776.66656.65576.4017.03286.45127.45427.022
    26.79726.99157.5216.95976.98517.00677.12837.77276.86277.2135
    36.74827.21287.29777.36346.86516.83747.0836.86277.38657.152
    46.97087.23647.11956.67997.00767.1526.99256.62877.10476.8315
    56.97787.48917.10547.23646.80466.97266.97556.81937.29637.152
    66.86817.3130 6.9570 6.62626.80466.83746.93446.58737.2005 7.3369
    平均值6.8422 7.2693 7.1796 6.9220 6.8538 6.8679 7.0244 6.8537 7.2175 7.1180
    标准偏差0.1177 0.1688 0.1998 0.3183 0.1305 0.2572 0.0718 0.4753 0.2143 0.1736
    相对标准偏差1.72%2.32%2.78%4.60%1.90%3.75%1.02%6.93%2.97%2.44%
    加标量7.50 7.50 7.50 7.50 7.50 7.50 7.50 7.50 7.50 7.50
    回收率91.23%96.92%95.73%92.29%91.38%91.57%93.66%91.38%96.23%94.91%
    准确度中浓度2.00mg/m3
    60.0ppm12345678910
    161.385561.492662.321462.0862.216862.158960.955460.836663.833863.2238
    261.193661.48962.015761.975262.109661.65860.814260.719362.874262.886
    361.154760.848862.012161.975262.004761.944460.607260.859562.968663.3598
    461.216261.78961.991561.967461.815761.671760.917960.304963.524362.482
    561.826261.99562.560162.578462.203161.65860.796460.574463.515462.2769
    661.6640 61.756162.4186 62.103362.258661.65860.877560.670363.4628 62.5229
    平均值61.4067 61.5618 62.2199 62.1133 62.1014 61.7915 60.8281 60.6608 63.3632 62.7919
    标准偏差0.2785 0.3989 0.2460 0.2354 0.1670 0.2127 0.1239 0.2040 0.3675 0.4362
    相对标准偏差0.45%0.65%0.40%0.38%0.27%0.34%0.20%0.34%0.58%0.69%
    加标量60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00
    回收率102.34%102.60%103.70%103.52%103.50%102.99%101.38%101.10%105.61%104.65%
    准确度高浓度3.00mg/m3
    90.0ppm12345678910
    187.5800 88.3600 87.9700 84.6400 86.8900 89.9900 85.5200 85.2000 88.3700 85.0400
    286.7159 87.1692 88.1087 87.6414 87.9892 88.3147 86.7899 86.6228 88.1320 87.6355
    387.0434 87.5221 87.8939 87.5662 88.4716 88.5945 86.9751 86.9240 89.1677 88.0790
    486.8849 87.6250 88.0238 87.4742 88.2040 88.4081 87.0541 86.7808 88.5321 88.2255
    587.3790 87.7248 88.0981 87.8216 88.7811 89.0492 87.4596 87.2456 89.3372 88.5529
    688.4467 87.6743 88.2959 87.6602 89.8993 89.1828 87.4156 87.1249 90.2937 88.6238
    平均值87.3417 87.6792 88.0651 87.1339 88.3725 88.9232 86.8691 86.6497 88.9721 87.6928
    标准偏差0.6275 0.3882 0.1388 1.2272 0.9880 0.6269 0.7098 0.7451 0.7975 1.3476
    相对标准偏差0.72%0.44%0.16%1.41%1.12%0.70%0.82%0.86%0.90%1.54%
    加标量90.00 90.00 90.00 90.00 90.00 90.00 90.00 90.00 90.00 90.00
    回收率97.05%97.42%97.85%96.82%98.19%98.80%96.52%96.28%98.86%97.44%
  • 该帖子已被版主-xiaogumd11加5积分,加2经验;加分理由:鼓励发帖
  • chun29
    第1楼2021/03/11
    HJ168-2020:对于目标物为多组分的分析方法,一般要求至少有 50%的目标物样品浓度在 3~5 倍计算出的方法检出限的范围内,同时,至少 90%的目标物样品浓度在 1~10 倍计算出的方法检出限的范围内,其余不多于 10%的目标物样品浓度应不超过 20 倍计算出的方法检出限。
    检出限的做法不符合标准要求。
  • 检测老菜鸟
    第2楼2021/03/12
    精密度和准确度加入标准品质量是如何得出来的?
  • 生活所迫
    第3楼2021/05/13
    就如2楼所说,测检出限的加标浓度太高了,可以考虑加0.5-0.8 ug,或许得出的结果比较比较合适,楼主统计的测定值小数位数太多了,看着密密麻麻的
