contact angle with water - 与水的接触角 critical surface energy - 临界表面能 taber abrasion - Taber磨损(试验)/ 磨耗性 chemical resistance - 耐化学性 water absorption - 吸水性 gas pereability - 气体渗透性
contact angle with water ;与水的接触角 critical surface energy ;临界表面能 taber abrasion ;....磨损 chemical resistance;耐化学,化学阻力 water absorption ;吸水性 gas pereability
