guichengkui
第7楼2007/10/07
acetaldehyde 乙醛;
acetic acid 乙酸;
acetic anhydride 乙酸酐;
acetoacetic ester 乙酰乙酸酯;
acetone 丙酮;
acetone titration 丙酮滴定法;
acetylation 乙酰化;
acetylene 乙炔;
acetyl group 乙酰基;
acetylenic bond 炔键;三键;
achiral molecule 非手性分子;
acidate 酸化,酰化;
acid-base equilibrium 算见平衡,
acid degree 酸度;
acid dissociation constant 酸离解常数;
acidic 酸式,酸性的;
acidic solvent 酸性溶剂;
acidity 酸度;
acidometer=acidimeter 酸度计;
acticarbon 活性炭;
activate 活化,激活,使…产生放射性;
activated state 活化态;
activating 活化;
activating agent 活化剂;
activator 激活剂;
active center 活性中心;
active group 活性基团;
active mass 有效质量;
active site 活性点;
actual column plate 实际塔板数;
adapter tube 接管;
additional peak 附加峰;
additivity 加和性;
adjacent 相邻的,邻位的
