液液萃取-气相色谱串联质谱法测定生活饮用水中土臭素和2-甲基异莰醇
摘要:
建立了液液萃取-气相色谱串联质谱法测定生活饮用水中土臭素(GSM)和2-甲基异莰醇(2-MIB)的方法,样品加入氯化钠、内标物质2-异丁基-3-甲氧基吡嗪,经乙酸乙酯液液萃取、浓缩,气相色谱串联质谱法进样检测,内标法定量。实验结果表明:曲线的线性相关系数均在R2>0.999,方法检出限分别为2.7ng/L、3.0ng/L,相对标准偏差(RSD)为96%~118%,加标回收率为0.7%~4.7%,均满足GB5749-2022的检测要求。该方法解决了GSM、2-MIB液液萃取重现性低、准确度不高、萃取效率低的问题,样品前处理简单,仪器设备简单,方便推广。具有分析快速、灵敏度高、重现性好的优点。
关键词:土臭素;2-甲基异莰醇;液液萃取;气相色谱串联质谱法
Determination of geosmin and 2-Methylisoborneol indrinking water by liquid-liquid extraction-gas chromatography-tandem massspectrometry
Abstract:ObjectiveA liquid-liquid extraction-gaschromatography-tandem mass spectrometry method was developed for thedetermination of GSM and 2-Methylisoborneol in drinking water, sodium chlorideand internal standard substance 2-isobutyl-3-methoxypyrazine were added intothe sample, and the sample was extracted, concentrated and ethyl acetate byliquid-liquid extraction, analyzed by gas chromatography-tandem massspectrometry, and quantified by internal standard method. The results showedthat the linear correlation coefficients of the curves were all in the range ofR2 >0.999. The detection limits were 2.7 ng/L and 3.0 ng/Lrespectively. The relative standard deviation (RSD) was 96% ~ 118% , and therecoveries were 0.7% ~ 4.7% , all meet the requirements of GB 5749-2022. Themethod solves the problems of low reproducibility, low accuracy and lowextraction efficiency of GSM and 2-MIB liquid-liquid extraction. The inventionhas the advantages of fast analysis, high sensitivity and good reproducibility.
Keywords:Geosmin; 2-methylisoborneol;Liquid-liquid extraction; Gas chromatography tandem mass spectrometry
土臭素(GSM)和2-甲基异莰醇(2-MIB)由放线菌、蓝藻等微生物代谢产生,往往会伴随夏季藻类暴发与代谢,导致地表水的水体中浓度大幅上升[1],是造成生活饮用水具有土霉味和腥臭味的主要原因。
生活饮用水中的土臭素(GSM)和2-甲基异莰醇(2-MIB)是目前造成生活饮用水具有土霉味和腥臭味的主要原因,主要是由放线菌、蓝藻等微生物代谢产生,往往会伴随夏季藻类暴发与代谢,导致地表水的水体中浓度大幅上升[1]。人的嗅觉对其极为敏感,GSM和2-MIB分别在1ng/L~10ng/L和5 ng /L ~10 ng /L时就能被闻到[2]。尽管它们不一定会对人体的健康造成威胁,但是因口感和味道不佳,常常使人们怀疑水质遭到污染而无法放心食用。近年来,随着工业的发展,突发嗅味事件时有发生[1]。新版《生活饮用水卫生标准》(GB 5749-2022)更是加大感官指标的关注,新增列入土臭素(GSM)和2-甲基异莰醇(2-MIB)两种典型土霉味物质。因此建立快速、灵敏度高、成本低、适宜大范围推广的检测方法十分必要。
分析检测嗅味物质的方法主要有感官分析法[3]- [4]和仪器分析法[5]- [4]两类,感官分析法因依靠个人嗅觉加以判断,存在无法准确定量、主观因素影响较大、环境要求较高等问题,因此应用受到一定限制。仪器分析法以气相色谱法[5]和气相色谱串联质谱法为主。嗅味物质目前主要前处理方法有固相微萃取法[6]- [7]、吹扫捕集[8]、固相萃取[9]- [10]、液液萃取[11]等;固相微萃取技术虽然操作简便、无需有机溶剂、萃取效率相对较高、结果准确,精密度高,但全自动固相微萃取价格昂贵,一般实验室难以承担;手动固相微萃取则需手动萃取及进样,检测效率不高,不适合大规模检测,且两种方式均存在萃取范围较窄,萃取纤维头价格昂贵、易碎、使用寿命短等问题。吹扫捕集是非平衡态连续萃取,是几乎能将所有的被测物萃取出来的定量萃取方法,故灵敏度较高,但设备昂贵,且吹扫过程耗费大量的惰性气体,使用成本较高。固相萃取不需要大量的有机溶剂,简化了预处理过程,避免了不必要的污染,但固相萃取所需样品体积大、上样及氮吹耗时较长,且准确性和回收率低于液-液微萃取法。虽然液液萃取存在方法的回收率和重现性差的问题,但其具有处理量大、分离效果好可连续操作、成本较低且易于操作等特点,是一种快速有效、经典适用的水样富集分析方法。目前,液液萃取嗅味物质的相关报道主要用到的溶剂是己烷和二氯甲烷,用乙酸乙酯作萃取剂的报道较少;同时液液萃取嗅味物质大多以外标法定量为主,以2-异丁基-3-甲氧基吡嗪作为内标法定量,在液液萃取中尚无相关报道。本文以乙酸乙酯作为液液萃取溶剂,萃取效率高,解决液液萃取回收率低的问题,而以2-异丁基-3-甲氧基吡嗪为内标,内标法定量,解决了液液萃取重现差的问题。本方法操作简单、检出限低、准确度高、重现性好,成本较低,且能满足GB5749-2022对土臭素和2-甲基异莰醇的要求。
实验部分
1.1主要仪器与试剂
GCMS-2010Ultra型气相色谱质谱联用仪(日本岛津);R-1001VN型旋转蒸发仪(郑州长城科工贸有限公司);KL512型氮吹仪(北京康林科技有限公司);涡旋混合器(VORTEX-5);数字可调移液器(BRAND);SH-Rxi-5SIl MS色谱柱(30m×0.25mm×0.25μm,日本岛津);正己烷、二氯甲烷、乙酸乙酯(德国默克,色谱纯);无水硫酸钠、氯化钠(400℃烘2h);甲醇中土臭素和2-甲基异莰醇混标(100μg/mL,北京北方伟业计量技术研究院);2-异丁基-3-甲氧基吡嗪(100μg/mL,Tmstandard)。
1.2 标准溶液的配制
土臭素和2-甲基异莰醇混合标准储备液(1μg/mL):准确移取浓度为100μg/mL的土臭素和2-甲基异莰醇混标0.1mL于10mL容量瓶中,用乙酸乙酯定容至刻度,摇匀备用。
2-异丁基-3-甲氧基吡嗪内标储备液(10μg/mL):准确移取浓度为100μg/mL的2-异丁基-3-甲氧基吡嗪标液1.00mL于10mL容量瓶中,用乙酸乙酯定容至刻度,摇匀备用。
标准系列工作溶液:准确移取浓度为1μg/mL的土臭素和2-甲基异莰醇混合标准储备液10、50、100、200、500μL;加入10μL浓度为10μg/mL2-异丁基-3-甲氧基吡嗪内标储备液,乙酸乙酯定容至10mL,配置成标准溶液浓度为1,5,10,20,50ng/mL;内标为10ng/mL的系列标准溶液。
1.3仪器条件
1.3.1气相色谱条件 色谱柱: SH-Rxi-5SIlMS色谱柱(30m×0.25mm×0.25μm);程序升温:60℃保持2.5min?以8℃/min升温至250℃?保持5min;进样口:250℃;柱流量:1.02mL/min?线速率控制模式;线速率:36.9mL/min;进样模式:不分流。
1.3.2质谱条件 离子源:EI源,离子源温度230℃;接口温度280℃;检测器电压0.90 kV;溶剂延迟时间2 min;扫描模式:选择离子检测(SIM)。土臭素、2-甲基异莰醇和2-异丁基-3-甲氧基吡嗪的选择性离子参数和保留时间如表1所示。
表1 土臭素、2-甲基异莰醇和2-异丁基-3-甲氧基吡嗪的选择性离子参数和保留
项目名称 | 保留时间/min | 定量离子(m/Z) | 定性离子(m/Z) |
土臭素 |
14.603
112
| 125 |
2-甲基异莰醇 |
10.628
95
| 107,135 |
2-异丁基-3-甲氧基吡嗪 |
10.294
124
| 94,151 |
1.4样品处理
取500mL水样移入1L分液漏斗中,加入20g氯化钠,加入浓度为1μg/mL的2-异丁基-3-甲氧基吡嗪内标储备溶液10μL,轻轻振摇;随后加入50mL 有机溶剂,轻轻震荡,放气,而后手动剧烈震荡萃取2 min,静置分层,将上层萃取液用无水硫酸钠脱水后转移至鸡心瓶中;下层水相再次加入50 mL乙酸乙酯,重复上述萃取步骤,经无水硫酸钠脱水后合并有机相;萃取获得的有机相先用R-1001VN型旋转蒸发仪45℃水浴蒸发至5mL左右,全部转移至氮吹管中,鸡心瓶中再加入2mL乙酸乙酯清洗,用涡旋混匀器混匀后,转移至氮吹管中。使用KL512型氮吹仪进行浓缩,控制氮气流速, 避免形成液面涡流, 45℃氮吹浓缩至1.0mL , 待上机分析。
2 结果与讨论
2.1实验条件的确定
2.1.1萃取剂选择
萃取溶剂对化合物的溶解性是影响萃取效率的最重要因素,而土臭素和2-甲基异莰醇的极性相对较大,所以本实验选择文献报道较多的萃取试剂正己烷、二氯甲烷,同时根据相似相容的原理,极性较大的溶剂对土臭素和2-甲基异莰醇萃取效果更好。而极性乙酸乙酯>二氯甲烷>正己烷,因此选择这三种萃取试剂进行比较。根据目标物峰面积大小,判断萃取效果。如图1所示。试验表明,乙酸乙酯萃取效果更好,其次是二氯甲烷,最后才是正己烷,符合上述极性推断萃取效率,且乙酸乙酯也是三者中毒性最低的,故选择乙酸乙酯作为萃取溶剂。
图1不同萃取剂对峰面积的影响
2.1.2萃取次数对回收率的影响
量取500mL含有10ng/L GSM、2-MIB浓度的水样, 混匀后, 按照1.4的样品前处理过程, 上机测试,用外标法定量计算目标物的回收率,以此对比萃取次数分别为1次、2次时的效果, 萃取1次时GSM、2-MIB的回收率分别为63%和78%,而萃取两次的回收率为90%和101%,可见萃取两次的回收率更高,且已满足前处理时对目标物回收率的要求, 故确定本试验前处理萃取次数为 2次。
2.1.3萃取体积的选择
采用液液萃取法时,萃取剂的体积一般为样品体积的1/10~1/3为宜。根据GB/T 5750.8-2023中GSM、2-MIB的检出限,本方法水样的富集体积为500mL,对比乙酸乙酯萃取体积为30 mL,40 mL,50 mL,60 mL时对目标物质峰面积的影响。结果见图2。由图2可见,当萃取体积达到50mL后,增加乙酸乙酯萃取体积对GSM、2-MIB萃取效率影响不大,考虑加大萃取体积增加经济成本,所以选择乙酸乙酯的萃取体积为50mL。
图2不同萃取剂对峰面积的影响
2.1.4萃取时间的选择
移取取500mL浓度为20ng/L 的GSM、2-MIB的水样,在其他条件不变情况下,考察了萃取时间分别为1min、2min、3min时对峰面积的影响,结果见图3。结果表明:由图3可知,萃取时间为2min与3min相比,GSM、2-MIB峰面积变化不大,萃取2min已经完全能满足使用要求,萃取3min虽目标物峰面积更高, 但操作步骤更为繁琐,试剂、时间耗费更多。因此萃取时间为2 min。
图3不同萃取时间的影响
2.1.5氯化钠加入量的选择
加入盐析剂氯化钠的量是影响萃取效率的一个重要因素, 足量盐析剂可确保GSM、2-MIB从水中完全析出, 从而进入到有机溶剂中, 用量不足则会导致萃取不完全, 回收率降低。本实验考察了氯化钠加入量分别为10g、15g、20g、25g 时对峰面积的影响,结果见图4。结果表明:由图4可知,当氯化钠加入量为20g以后,GSM、2-MIB峰面积变化不大,故氯化钠加入量为20g。
图4氯化钠加入量对峰面积的影响
2.1.6浓缩方式的选择
浓缩方式是影响富集效率的一个重要因素,不当的浓缩方式会引起目标物的损失。目前主要的浓缩方式主要有旋转蒸发和氮吹两种。而水中的异嗅物质多为挥发性或半挥发性有机物,因此选择合适的浓缩方式尤为重要。因本试验萃取体积为50mL,萃取两次,大约100mL左右,单纯用氮气吹干用气量比较大,且用时较长。故本文采取旋转蒸发和旋转蒸发与氮气联用进行比较。用旋转蒸发蒸至近干,再定容至1.00mL时,GSM的回收率为39.3%,2-MIB的回收率为19.7%。而先用旋转蒸发仪蒸发至5mL左右,再用氮气吹至1.00mL,GSM的回收率为89.7%,2-MIB的回收率为101%。故选择先用旋转蒸发蒸去大部分萃取溶剂后,再用氮气吹至1.00mL效果更好,即可以回收大部分萃取溶剂,避免污染环境,又可保证目标物的回收率。
2.2标准曲线的线性关系及检出限
在优化试验条件下,以标准系列中的物质浓度为横坐标,以目标物质的峰面积与内标物的比值为纵坐标,绘制工作曲线,结果见表1。同时以3倍信噪比表示方法检出限,对应浓度即为最低检出浓度。结果见表2,可见,两种物质的检出限均能够满足GB 5749-2022的要求。
表2GSM和2-MIB表线性回归方程及方法检测限
组分名称 | 标准曲线回归方程 | 相关系数(r) | 检出限(μg/L) |
GSM | y=0.102412x-0.001045 | 0.9995 | 2.7 |
2-MIB | y=0.109154x+0.025366 | 0.9996 | 3.0 |
2.3方法的准确度及精密度
取3组500mL纯水,分别加入1ng、10ng、50ng的GSM和2-MIB混合标准溶液,每组平行测定6次,计算平均回收率和相对标准偏差(RSD),测定结果见表3。测得回收率在96%~118%;RSD为0.7%~4.7%,表明该方法具有较好的准确度与精密度。
表3GSM和2-MIB平均回收率及精密度(n=6)
化合物 | 加入量(ng) | 测得平均值(ng) | 回收率(%) | RSD(%) |
GSM | 1 | 1.18 | 118 | 3.9 |
| 10 | 11.49 | 115 | 2.1 |
| 50 | 49.6 | 99.2 | 0.8 |
2-MIB | 1 | 0.961 | 96.1 | 3.4 |
| 10 | 9.723 | 97.2 | 4.7 |
| 50 | 49.21 | 98.4 | 0.7 |
2.4实际样品的测定
分别运用优化后的液液萃取方法和GB/T 5750.8-2023标准固相微萃取方法测定了某市自来水厂重要工艺段中的嗅味物质?测定结果见表 1。
表3某自来水厂工艺节点水样测定结果
工艺节点 | 液液萃取测定结果(ng/L) | 固相微萃取测定结果(ng/L) |
GSM | 2-MIB | GSM | 2-MIB |
沉淀池出口 | 11.0 | 104 | 9.7 | 121 |
碳滤池出口 | 未检出 | 7.6 | 未检出 | 8.4 |
出厂水 | 未检出 | 未检出 | 未检出 | 未检出 |
由测试结果可知,沉淀池出口的水样均含有GSM和2-MIB,其中2-MIB含量较高,经活性炭过滤后能去除大部分2-MIB,而出厂水均未检出GSM和2-MIB。
3 结论
本方法根据土臭素和2-甲基异莰醇极性大的特点,选取乙酸乙酯作为萃取剂,同时对萃取次数、萃取剂体积、萃取时间和氯化钠加入量等进行了优化,提高了萃取效率,参照GB/T 5750.8-2023标准,在液液萃取中引入2-异丁基-3-甲氧基吡嗪作为内标,解决了液液萃取准确度不高、重现性不好的问题。旋转蒸发和氮吹联合使用,利用旋转蒸发回收大部分萃取溶剂,避免污染环境,提高检测效率,而氮吹则提高土臭素和2-甲基异莰醇的回收率。两种物质在1.0~50.0 ng/mL范围内线性良好,检出限分别为2.7 ng/L 、3.0 ng/L,在低、中、高3个加标水平下的回收率为96%~118%,RSD为0.7%~4.7%。本方法操作简单、检出限较低、准确度高、重现性好,检测成本较低,可用于生活饮用水中土臭素和2-甲基异莰醇的测定。
参考文献
[1]张永鑫,仇付国,王春苗,等.我国饮用水嗅味问题的发生、主要嗅味物质及来源[J].环境科学学报,2023,43(12):65-75.
ZHANGYongxin,QIU Fuguo,WANG Chunmiao,et al.The occurrence,main odorants and sources of drinking water odor problems in China[J].Acta Scientiae Circumstantiae, 2023,43(12) : 65-75.
[2]郭继征,王敬敏.生活饮用水主要致嗅物质及其处理[J].工业技术与职业教育,2016,14( 2) : 10-11,18.
Guo Jizheng, Wang Jingmin. Main odor causing substancesin drinking water and processing[ J ] . Industrial Technology and Vocational Education,2016,14(2) : 10-11,18.
[3]JEROEN H M,BARTELS,BRADY B M, etal. Trainingpanelists for the flavor profile analysis method[J].JAWWA,1987,79:1-26.
[4]张杨,张福全,等. 嗅味层次感官分析法在水质检测中的应用[J].产业与科技论坛,2014,13(20):74-75.
ZhangYang, Zhang Fuquan, et al.Application of smell-taste hierarchical sensoryanalysis in water quality detection [ J ] . Industry and Science Tribune,2014,13(20) : 74-75.
[5]马晓雁,高乃云,李青松,等.气相色谱法测定饮用水中痕量土臭素和二甲基异冰片[J].分析测试学报,2007,26(2):267-269.
Ma Xiaoyan, Gao Naiyun, Li Qingsong, et al. Determination of trace geosmin in and2-methylisobomeol in drinking water by Gas chromatography[ J ]. Journal of InstrumentalAnalysis, 26(2) : 267 -269.
[6]周广安,陈漪洁,潘慧慧,等.全自动固相微萃取-气相色谱串联质谱法检测水中土臭素和2-甲基异莰醇[J]. 净水技术,2021,40(5):46-50.
ZHOU G A,CHEN Y J,PAN H H,et al.Automatic detection method of 2-MIB andGSM in water by SPME-GC-MS /MS[J].Water Purification Technology,2021,40(5): 46-50.
[7]蔺洁,于彤. 气相色谱质谱法测定水中土臭素和二甲基异莰醇[J].供水技术,2017,11(4):53-54.
Lin Jie, Yu Tong. Determination of geosmin and 2-methylisobomeol in water by gas chromatography-mass spectrometry [ J ] .WaterTechnology, 2017,11(4) : 53-54.
[8]乐洋,孙坚伟.吹扫捕集气相色谱—质谱联用测定水中二甲基异莰醇和土臭素[J]. 净水技术,2015,34(4):55-59.
Le Yang,Sun Jianwei. Determination of 2-Methylisoborneol and Geosmin inWater by Purge and Trap Technology with Gas Chromatography /Mass Spectrometry( GC/MS)[J]. Water Technology, 2015,34(4):55-59.
[9]李福安,张焕伟,巢猛,等.固相萃取-气相色谱法测定土臭素和2-甲基异冰片[J]. 供水技术,2011,5(2):54-55.
Li Fu'an, Zhang Huanwei,Chao Meng, et al. Solid-Phase Extraction-Gas Chromatography Method for theDetermination of Geosmin and 2-Methylisoborneol [J]. WaterTechnology,2011,5(2):54-55.
[10]宋帅帅,王晓波,田立平,等.固相萃取-气质联用测定水体中的土臭素和二甲基异冰片[J]. 供水技术,2016,26(1):23-25.
SongShuaiShuai, Wang Xiaobo, Tian Liping, et al.Determination of geosmin anddimethyl isobornol in water by solid-phase extraction gas chromatography-massspectrometry[J]. Water Technology, 2016,26(1):23-25.
[11]马杰,方赤光,李青,等.气相色谱-质谱联用法测定生活饮用水中的土臭素和2-甲基异莰醇[J]. 中国卫生检验杂志,2014,8(3):50-52.
MA Jie,FANG Chiguang,LI Qing,et al. Determination of geosmin and 2-methylisoborneolin drinking water by gas chromatography-mass spectrometry[J]. Chin J Health LabTec, 2014,8(3):50-52.
