【讨论】预留座位是否应该译为"reserved seat"还是直接写reserved?
  • 六脉神剑
    2007/05/31
专业英语
  • 如果给某人预留座位,是否将预留座位译为"reserved seat"或者直接写reserved?
    各位大侠给指点一二!
  • happyjyl
    第1楼2007/05/31
    可以用reserved seat。预留座位的票是reserved-seat ticket。
  • 闲鹤野云
    第2楼2007/05/31
    It is reserved. or This is a reserved seat. This seat is reserved. or Can you please reserve one room for us, we will be there in, say, half an hour.
    quanbaogang 发表:如果给某人预留座位,是否将预留座位译为"reserved seat"或者直接写reserved?
    各位大侠给指点一二!
  • 六脉神剑
    第3楼2007/05/31
    谢谢两位,我最后还是打算用”RESERVED“。因为我要打印出来贴在座位上,简练的表达是最合适的。大家的意思呢!?
  • 茅茅
    第5楼2007/05/31
    突然想到一个词:engaged. 应该也是这个意思吧?参与讨论,不敢自称为大侠。
  • happyjyl
    第6楼2007/05/31
    如果是贴在座位上,还是写reserved较好.
  • 六脉神剑
    第7楼2007/05/31
    I appreciate your help! You all are very learned and warmhearted!
  • 闲鹤野云
    第8楼2007/05/31
    not wormhearted but warmhearted.4, All of you are learned and ...
    quanbaogang 发表:I appreciate your help! You all are very learned and wormhearted!
  • mfxhuang
    第9楼2007/06/01
    Engaged 一般指订婚的
  • 何当奇
    第10楼2007/06/01
    re•served (r -zûrvd )
    adj.
    1. Held in reserve; kept back or set aside.
    2. Marked by self-restraint and reticence. See Synonyms at silent.
    re•serv ed•ly (-zûr v d-l ) adv.
    re•serv ed•ness n.
    The American Heritage® Dictionary of the English Language, Fourth Edition copyright ©2000 by Houghton Mifflin Company. Updated in 2003. Published by Houghton Mifflin Company. All rights reserved.
    ThesaurusLegend: Synonyms Related Words Antonyms
    Adj.    1.    reserved - set aside for the use of a particular person or party
    unreserved - not reserved
    2.    reserved - marked by self-restraint and reticence; "was habitually reserved in speech, withholding her opinion"-Victoria Sackville-West
    backward - (used of temperament or behavior) marked by a retiring nature; "a backward lover"
    undemonstrative - not given to open expression of emotion
    inhibited - held back or restrained or prevented; "in certain conditions previously inhibited conditioned reactions can reappear"
    restrained - under restraint
    unreserved - not cautious or reticent; "unreserved behavior"
    3.    reserved - cool and formal in manner
    restrained, reticent, unemotional
