【求助】紧急求助全文
  • myflower_1982
    2007/06/21
农残检测
  • 紧急求助全文;
    1.Determination of pymetrozine residues in cucumber.
    Talebi K, Ghazizadeh Ahsaii H.
    Dept. of Plant Protection, College of Agriculture, University of Tehran, Karaj 31585, Iran.
    An experiment was carried out to investigate the residues of pymetrozin in cucumber under field conditions. Plots of cucumber (cv. Daminus) were sprayed with pymetrozine (Chess, WG50) at two different rates; 0.5 and 1.0 kg/ha. Samples were collected 2 hours and 1, 2, 3, and 4 days after spraying and pymetrozin residues were determined using high performance liquid chromatography with UV detector. Two hours after spraying, the residues was 0.326 mg/kg for 0.5 kg/ha treatment. The residues decreased to 0.013 mg/kg on the third day and no residue was detected four days after spraying. In 1.0 kg/ha treatment, the residue was 0.627 mg/kg, two hours after spraying, which decreased to 0.028 mg/kg, on the third day, but no residues was found in samples which collected four days after spraying. In farm plots which received 0.5 kg/ha pymetrozine, the residues in peels and peeled cucumber were 0.359 and 0.308 mg/kg respectively, two hours after spraying, but in plots which sprayed at 1.0 kg/ha, the residues were 0.648 and 0.609 mg/kg respectively. Furthermore the residues in peels showed a significant difference with those of peeled and unpeeled cucumber under field conditions.
    Commun Agric Appl Biol Sci. 2006;71(2 Pt A):75-8.
    2 .Research Article
    A multi-residue screening method for the determination of 73 pesticides and metabolites in fruit and vegetables using high-performance liquid chromatography/tandem mass spectrometry
    Christel L. Hetherton 1, Mark D. Sykes 1 *, Richard J. Fussell 1, David M. Goodall 2
    1Central Science Laboratory, Sand Hutton, York YO41 1LZ, UK
    2Department of Chemistry, University of York, Heslington, York YO10 5DD, UK
    email: Mark D. Sykes (m.sykes@csl.gov.uk)
    *Correspondence to Mark D. Sykes, Central Science Laboratory, Sand Hutton, York YO41 1LZ, UK
    Rapid Communications in Mass Spectrometry
    Volume 18, Issue 20 , Pages 2443 - 2450
  • 我在故我思
    第1楼2007/06/21
    附件
