何当奇
第6楼2007/07/26
Hold Up Time (tm) methane
The time for an injected substance, which is not retained on the stationary phase, to pass through the column and reach the detector. Hold Up Time is usually measured by injection of a compound such as methane.
Retention Time (tR)
The time between injection and the appearance of the peak maximum.
