gavin_icp
第5楼2007/08/18
Flag Description
o Replicate over-range
QC The QC test has failed
S Standard addition failure
e Edited result
c Uncalibrated results
i No internal standard
n Interference correction was not applied (the IEC table was not set up correctly or the matrix calculation was not evaluated)
a The solution was overrange and diluted automatically
u Under-range (< blank)
v Under valid range (< minimum concentration)
x Extended calibration range (> maximum concentration)
b The line has a related interferent that is overrange
p (Liberty only) Spectral overlap
m (Liberty only) Multiple peak
d (Liberty only) No peak found
C Replicate non-convergence (fitted background was not evaluated)
D Insufficient spectral data
