【求助】weighted linear regression翻译
  • sunrain001
    2007/12/02
专业英语
  • Where three or more levels are utilised, an appropriate calibration
    function may be calculated and used between the lowest and highest calibrated levels. The calibration curve (which may or may not appear to be linear) should, in general, not be forced through the origin. The fit of the calibration function must be plotted and inspected visually and/or by calculation of the residuals,
    avoiding reliance on correlation coefficients, to ensure that the fit is satisfactory in the region relevant to the residues detected. If individual residuals deviate by more than ±20% (±10% in cases where the MRL is approached or exceeded) from the calibration curve in the relevant region, an alternative calibration function must be used. In general, the use of weighted linear regression is
    recommended, compared to linear regression.
    请教,最后一句的linear regression 和weighted linear regression怎么理解?
  • 我在故我思
    第1楼2007/12/02
    linear regression: 直线回归、线性回归
    weighted linear regression: 加权直线回归
    sunrain001 发表:最后一句的linear regression 和weighted linear regression怎么理解?
  • 该帖子已被版主-闲鹤野云加2积分,加2经验;加分理由:鼓励应助
  • happyjyl
    第2楼2007/12/03
    楼主只要以“weighted linear regression”为关键词(注意打双引号)在google上搜索一下简体中文网页就能看到结果了。
  • sunrain001
    第3楼2007/12/03
    谢谢楼上各位帮助!
  • 深海的海豚
    第4楼2007/12/04
    请教happy一下为什么要打双引号呢? 谢谢!
    happyjyl 发表:楼主只要以“weighted linear regression”为关键词(注意打双引号)在google上搜索一下简体中文网页就能看到结果了。
  • sun-quansheng
    第5楼2007/12/04
    直线回归和加权直线回归
  • 何当奇
    第6楼2007/12/04
    打双引号的话,搜索将按照词组来进行
    lqqer 发表:请教happy一下为什么要打双引号呢? 谢谢!
  • qiuhan2010
    第7楼2007/12/04
    线性回归和加权线性回归
  • 该帖子已被版主-何当奇加1积分,加2经验;加分理由:鼓励新手应助
