poorlittle
第6楼2008/01/25
I supposed that 实验, 小剂量, 中剂量, 大剂量, 对照组 should be translated as experiment, small dose, medium dose, large dose and comparison group (or reference). After reading the paper recommended by redanqi at 5/F, I learnt that the appropriate translation should be test, low-dose, mid-dose, high-dose and control respectively.
真是隔行如隔山, 幸好没随便建议, 否则真是汗了。
shan00509
第7楼2008/01/25
Experimental animal: The dog, divides female, male.
The experiment groups: The experiment apportioned the medicine conclusion time and 4 week recovery period two stages, each time was divided four groups: Control group, small monitoring team, monitoring team, big monitoring team. For medicine conclusion time each groups of female 2 male 1, restored conclusion time male 1 female 2, the pathology inspection altogether 24 dogs.
Experiment material: Each animal takes the heart, the liver, the spleen, the lung, the kidney, the brain, the stomach, the intestines, the adrenal gland, the thyroid gland, the male gender takThe neutral cushion formalin is fixed, the conventional dehydration, transparent, soaks the wax. Slice thick 4~5m, HE dyes, under the mirror observes. cardiac muscle: control group: The muscle fiber assumes ties the shape, the nuclear ellipse shape, located at the muscle fiber central committee, between the muscle fiber has the knot to contract the organization and the minute vessel, the muscle fiber across to the grain, the female and male animal cardiac muscle is obviously normal. When recovery period conclusion the control group 3 animal cardiac muscle are normal. small monitoring team: The muscle fiber assumes ties the shape, between the muscle fiber has the knot to contract the organization and the minute vessel, the muscle fiber across to the grain, the female and male animal cardiac muscle is obviously normal. The recovery period ended with the control group, normal.in monitoring team: With the control group, the female and male animal cardiac muscle is normal. The recovery period ended with the control group, normal. big monitoring team: The muscle fiber assumes ties the shape, obviously across to the grain, compares with the control group does not have exceptionally. Resumed the conclusion cardiac muscle organization to be normal. liver: control group: Obviously the hepatic lobe, take the central vein as the center, the liver cell assumes the strip funicular to all around to emit, the central vein cavity is big, the liver cell assumes the polygon, the nucleus garden shape located at the cell central committee. By the interlobular vein, the interlobular bile duct are composed the hepatic duct area. The female and male animal is normal. The recovery period conclusion liver structure was normal. small monitoring team: With control group, obviously hepatic lobe, liver rope disciple district. The female and male animal is normal. The recovery period conclusion liver structure was normal.in monitoring team: With control group, obviously hepatic lobe, liver rope disciple district. Female and male animal under normal. The recovery period finished the female and male animal structure to be normal. big monitoring team: 3 animal liver cells have varying degree swelling, liver cell vanishing, the venula expand, liver Dou hyperemia. The recovery period ended 1 male animal liver organization hyperemia, other 2 liver structure was normal. es the testicle, the female takes the womb.
