熊猫宝宝
第6楼2008/06/24
楼主可以参考这个:
The 3 D braiding technique for composites is a new textile technology developed in the United States in the 80s. The composite of 3 D braided structure is a new kind of composites. Its shock damage resistant property, mechanical property and fire resistant property are fairly good. In this paper, the unit cell geometry of the 3 D braided structure of composites was discussed and the relationships of the structural parameters were established.
复合材料三维编织结构技术是国外八十年代发展起来的高新纺织技术。三维编织结构复合材料是一种新型结构形式的复合材料,它具有优良的抗冲击损伤性能、力学性能和耐烧蚀性能。本文讨论了三维编织结构的单元体模型,推导出有关参数之间的数学关系
cell geometry , 再根据你的测试项目, 应该是空间的几何结构, 因为cell有小房间的意思, 所以是否可以引申为你测试的种出现的一种空间存在呢??
这个只是我个人的看法
poorlittle
第8楼2008/06/24
以前学工程材料学时, 接触过材料之微观结构, cell geometry 可能与此有关。 不过详情已忘了, 或可参考以下资料:
The cell geometry within a typical ceramic substrate is either square or triangular. Cell geometry affects pressure drop, heat transfer characteristics, and the thermomechanical integrity of the substrate.
http://www.memagazine.org/backissues/membersonly/march99/features/durability/durability.html
Crystal Structure
for crystalline materials, the manner in which atoms or ions are arrayed in space. It is defined in terms of the unit cell geometry and the atom positions within the cell.
http://www.tulane.edu/~bmitche/book/glossary.html
The unit cell geometry is completely defined in terms of six arameters(sometimes termed the lattice parameters) :the three edge lengths, a、b and c, and the three interaxial angles, α、β and γ
http://www.lib.cycu.edu.tw/exams_new/master/mbe/95/mbe95201.pdf
Cell geometry : identification of grid data as point or cell Mandatory
http://www.fao.org/geonetwork/srv/en/help.metadata?schema=iso19115&name=cellGeo
