【求助】帮忙看有关GC分流/不分流的一句描述
专业英语
  • In the work described here, pulsed splitless injection methods (with
    MS detection in scan and SIM modes) were compared against a split injection method (with MS detection in scan mode). The lowest concentration measured using split injection corresponded to 20 ppb reaching the column (i.e., 1/25 of the 0.5 ppm concentration
    of a prepared standard or extract). This was close to the limit of detection (LOD) for a method based on split injection/scan mode.
    其中reaching the column 怎么翻译好?
  • 何当奇
    第1楼2008/07/16
    这个没有翻译过。难道是指流过柱子的浓度为20ppb?是不是应该是 is measured?如果measured这个句子就很奇怪了
    uhlan 发表:In the work described here, pulsed splitless injection methods (with
