【讨论】翻译:本报告仅对提供的样品负责 (Suggested Alternative)
  • poorlittle
    2008/07/17
专业英语
  • Since christe’s post has been locked, I submit a new post to suggest an alternative translation :
    Unless otherwise stated the results shown in this test report refer only to the sample(s) tested.
    Sometimes, if the properties of the sample also vary with time, you may also need to add “at the time of testing”
    Your may find many other similar remarks from Google with the keywords “test, report, sample, time of testing”. Such remarks are essential from legal point of view.
  • 该帖子已被版主-何当奇加3积分,加2经验;加分理由:精辟
  • poorlittle
    第1楼2008/07/17
    poorlittle 发表:Since christe’s post has been locked, I submit a new post to suggest an alternative translation :
    Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. (see http://www.shenmao.com/files/doc/PF649(080616).pdf )
  • huganguo
    第2楼2009/07/11
    楼主的确仔细过人 天天翻看这些公证行的报告却没有发现这些细节 实在是不该
