poorlittle
第1楼2009/01/18
似是一些管道用之配件, 以“Compression Tube Fittings”为keywords, lots of images can be found from Google ( http://images.google.com.hk/images?q=compression%20tube%20fittings&hl=zh-TW&lr=lang_zh-TW&um=1&ie=UTF-8&sa=N&tab=wi )
for example:
http://images.google.com.hk/imgres?imgurl=http://www.indiamart.com/fitwelengineeringworks/pcat-gifs/products-small/compression-tube-fittings_10506720.jpg&imgrefurl=http://www.indiamart.com/fitwelengineeringworks/industrial-products.html&usg=__EoclZLe6XcDn54pyj6fqyw5FZbo=&h=240&w=240&sz=14&hl=zh-TW&start=1&um=1&tbnid=jwYmm5VEfNZBDM:&tbnh=110&tbnw=110&prev=/images%3Fq%3Dcompression%2Btube%2Bfittings%26um%3D1%26hl%3Dzh-TW%26lr%3Dlang_zh-TW%26sa%3DN
但不知是否和spfxyqc所指有关。
