【分享】NCI在农药残留测定中的应用
  • 快乐
    第1楼2009/01/23
    这是我们不常用的,谢谢提供这方面的资料,学习了
    特别是有了比较,很清晰
  • 第2楼2009/01/23
    NCI的确用的不多,个人认为ci主要用途是获取分子量……
  • 我在故我思
    第3楼2009/01/25
    http://www.public.iastate.edu/~kamel/ci.html
    这个网站对CI和NCI有一些介绍。
  • 我在故我思
    第4楼2009/01/25
    Negative Ion Chemical Ionization- Gas Chromatographic–Mass Spectrometric Determination of Residues of Different Pyrethroid Insecticides in Whole Blood and Serum
    Atmakuru Ramesh; Perumal E. Ravi
    Abstract:
    A new rapid and sensitive analytical method using negative ion chemical ionization-gas chromatography–mass spectrometry in selective ion monitoring mode has been developed for the determination of residues of different synthetic pyrethroid insecticides, allethrin, bifenthrin, cypermethrin, cyphonothrin, cyfluthrin, l-cyhalothrin, deltamethrin, fenvalerate, fenpropathrin, permethrin, prallethrin, and trans-fluthrin, in whole blood. The residues of pyrethroid molecules were extracted from the whole blood using a hexane and acetone (8:2, v/v) solvent mixture without separating the serum. The method was found sensitive to detect the residues of pyrethroids up to the level 0.2 pg/mL. Experiments conducted with the whole blood samples at the fortification level 1–100 pg/mL showed 91–103% recovery, whereas blood serum samples collected after the fortification of pyrethroids in whole blood showed 36–54% recovery. Recovery experiments conducted by direct fortification of pyrethroids in blood serum samples showed 96–108%. The applications of the analytical method was tested by analyzing 73 human blood samples collected from the population exposed continuously to different pyrethroid-based formulations. None of the blood samples showed residues of pyrethroids. The results were also confirmed by the detection of the appropriate amounts in a number of these samples, which had subsequently been spiked with known quantity of pyrethroids.
    http://www.ingentaconnect.com/content/pres/jat/2004/00000028/00000008/art00007
  • 我在故我思
    第5楼2009/01/25
    Characterization of Gas Chromatography-Negative Ion Chemical Ionization Mass Spectrometry for Ambient Measurement of PAN: Potential Interferences and Long-Term Sensitivity Drift
    Hiroshi Tanimoto,et al.
    Abstract:
    Gas chromatography/negative ion chemical ionization mass spectrometry (GC/NICI MS) is characterized, elucidating instrument performance for the continuous measurement of peroxyacetyl nitrate (PAN) and its homologues. Chromatograms and linear response at parts per trillion by volume (pptv) levels are examined to evaluate the accuracy of calibration using 4 types of base gases: dry nitrogen, dry synthetic air, purified compressed air, and thermally PAN-decomposed air. The sensitivity to PAN is further checked against humidity, which may be a source of interference in ambient measurements. The experimental results indicate that oxygen, water vapor, and other trace gases in ambient air do not affect the PAN sensitivity. Although significant sensitivity drifts were observed during the course of measurements made at a remote site in Japan, this problem was overcome by performing frequent calibrations with isopropyl nitrate (IPN).
    http://www.agu.org/pubs/crossref/2000/1999GL011284.shtml
  • 雾非雾
    第6楼2013/04/27
    The Usefulness of Negative Chemical Ionization and a Mass Spectral Library for Pesticide Residues in Food
  • 西北风
    第7楼2013/04/29
    基质固相分散和GC—NCI—MS法分析果汁中拟除虫菊酯农药残留量
