对干固体含量为77%的HFS 55:
用分析天平称量1.5克样品到一个小瓶子中。用自动移液管加入0.5ml1.0%磷酸。用瓶口移液器或移液管加入8.5ml纯化水。立即加盖。
czj_1027 发表:For HFS 55 with 77% d.s.
Using an analytical banance weith 1.5g of sample into a vial.Add 0.5ml of 1.0%H3PO4 using an automatic pipette.Add 8.5ml of purified water using a dispensette or pipette. Cap immediately.
整段翻译应该是什么意思?
