fanyegeng
第1楼2009/06/26
Migration studies from paper and board food packaging materials. 1. Compositional analysis.Castle L, Offen CP, Baxter MJ, Gilbert J.
Ministry of Agriculture, Fisheries and Food, CSL Food Science Laboratory, Colney, Norwich, UK.
A survey of 32 paper and board materials intended for food contact has been undertaken. Sample composition was analysed to identify chemicals with a potential to migrate to foods. Representative materials covering a range of uses such as aqueous and fatty foods, and use at ambient and elevated temperatures, were obtained from industry. The samples were examined in their unfinished state, even where the final form would have included lamination to plastics, printing, or other treatments. A comprehensive and systematic analytical approach was applied which included determination of volatiles by headspace GC-MS, extraction using water, ethanol and chloroform with subsequent analysis by GC-MS and HPLC, and multi-element screening by ICP-MS. The solvent extracts were also weighed to determine the total amount of material available for migration. A large number of volatile substances were identified with alkyl and aryl aldehydes predominating in the majority of samples. Substances identified in solvent extracts included 2,6-di-tert-butyl-4-hydroxytoluene (BHT), di-tert-butylphenol, benzophenone, 4,4'-bis(dimethyl amino) benzophenone (Michler's ketone), triphenyl methane, bicyclohexylphenylphenanthrene carboxylic acid (and its methyl ester) and abietic acid. Levels of these substances were however generally below 1 mg/kg paper. Of the inorganic elements, arsenic and mercury were not detected above the limits of determination of 1.8 and 0.4 mg/kg respectively in any of the 10 samples examined. Cadmium was detected in teabag tissue and in unbleached Kraft paper at 0.3 mg/kg. Chromium was present in seven samples at 1.1-7.8 mg/kg, whilst lead was present in nine of the 10 samples at levels ranging from 0.3 to 5.9 mg/kg.
PMID: 9059581 [PubMed - indexed for MEDLINE]
Related articles
Migration studies from paper and board food packaging materials. Part 2. Survey for residues of dialkylamino benzophenone UV-cure ink photoinitiators. Food Addit Contam. 1997 Jan; 14(1):45-52.
[Food Addit Contam. 1997]
Benzophenone in cartonboard packaging materials and the factors that influence its migration into food. Food Addit Contam. 2003 Jun; 20(6):607-18.
[Food Addit Contam. 2003]
Toxicity testing and chemical analyses of recycled fibre-based paper for food contact. Food Addit Contam. 2002; 19 Suppl:13-28.
[Food Addit Contam. 2002]
ReviewCurrent research on food contact materials undertaken by the UK Ministry of Agriculture, Fisheries and Food. Food Addit Contam. 1994 Mar-Apr; 11(2):231-40.
[Food Addit Contam. 1994]
ReviewMigration of substances from food packaging materials to foods. Crit Rev Food Sci Nutr. 2004; 44(2):63-76.
[Crit Rev Food Sci Nutr. 2004]
» See reviews... | » See all...
Cited by 1 PubMed Central article
ReviewEffects of micronutrients on metal toxicity. Peraza MA, Ayala-Fierro F, Barber DS, Casarez E, Rael LT. Environ Health Perspect. 1998 Feb; 106 Suppl 1:203-16.
[Environ Health Perspect. 1998]
只找到摘要啊~~
