阿宝
第7楼2009/08/18
AIA(ANDI) Conversion
________________________________________
If you select "*.cdf" for an extension when naming a data file to save it, the data file can be saved as an AIA file. This window allows you to select the conversion mode in which to create an AIA file.
The spectra in such as noise data may include the negative intensity. If this negative value is converted into an AIA file, which is then loaded by another software, an error may occur unless that software supports negative values. In this case, change the conversion mode for negative values to carry out AIA conversion.
上面是我在GCMS Solution 里面的 帮助 里面搜索出来的转化步骤。
我今天用岛津的GCMS Solution试了一下,成功转化为AIA!步骤如下:
把需要转化的文件打开,另存为扩展名为cdf的文件,就ok了!希望对楼主有帮助!!!
