jiaoqingbo
第1楼2009/11/06
cup cuvette 放标液的杯子(或是杯状的比色杯)
ring 环(不知道什么上的)
tube cuvette 样品杯(管状的比色杯)
glass atomizer set 雾化器设置(glass玻璃,atomizer雾化器 set设置;原吸上玻璃材质的雾化装置设置应该只有指雾化器设置了)
以下是现在的热电的配件的标示:
ridge tube 尖底离心管
uncoated cuvette 普通石墨管
pyrolytically coated electrographite cuvettes 热解涂层石墨管
Atomic Absorption Featured Products...
Cuvette Types
Standard graphite cuvettes provide cost-effective analysis of volatile elements in simple samples, while coated cuvettes are ideal for high temperature. The Extended Lifetime Cuvettes (ELCs) offer long lifetimes and handle aggressive matrices, while the Omega platform cuvettes combine the interference control with longevity.
Material Number Description
9423 393 95031 Graphite, Ridged/Uncoated, 10 pack
9423 393 95071 Graphite, Ridged/Coated, 10 pack
9423 393 95091 Graphite, Unridged/Coated, 10 pack
9423 393 95041 Extended Lifetime, 10 pack
9423 393 95051 Extended Lifetime, 20 pack
9423 490 20101 Omega Platform, 10 pack
热电的参考网址:http://www.thermo.com/com/cda/article/general/1,,20395,00.html
参照热电的翻译,日本的“cup cuvette”和“tube cuvette”也可能是石墨管一类的,不敢肯定。只供参考。
最好对照上实际照片看。
