何当奇
第2楼2009/12/28
1) The test article was carbofuran technical rather than a formulation or dilution of the formulation. EPA Dermal Penetration (i.e., adsorption) guidelines (OPPTS 870.7600) specify that the vehicle system used for this study should “duplicate” that under which field exposure occurs. The basic vehicle is usually the material used in the commercial formulation.”
检测物质为carbofuran原药而不是一个制剂,或者制剂的稀释液。EPA 皮肤渗透(如吸收)准则(OPPTS 870.7600)明确说明用于本实验的介质应“加倍”田间发生的曝露。基础介质通常为商品制剂中的所用的物质。
poorlittle
第5楼2009/12/29
I see. I did not aware that this was about pesticide.
Last month, I took a tour in New Zealand and experienced the feeling of standing on the field. As a person spending the whole life in city, the real “field” (原野、田间) and “farm” (农庄) are very impressive.
何当奇
第6楼2009/12/29
那是做梦的地方啊
何当奇
第7楼2009/12/29
2) The vehicle used in the study, acetone, enhanced dermal absorption of the test material beyond what would reasonably be expected. Carbofuran is an insoluble solid, formulated as a water-based suspension that contains no acetone or organic solvents. EPA Dermal Penetration guidelines specifically state that “a neutral suspending agent which does not interact with the test chemical of affect the permeability of the skin - - may be used. However, organic solvents or special solubilizing/suspending agents must not be used.” 本实验中所使用的介质,丙酮,增强了实验物质合理预期的皮肤吸收。Carbofuran 是一个不溶性固体,制剂为不含丙酮或有机溶剂的水基悬浮液。EPA经皮渗透准则明确指出 可以使用一个不与检测物质反应而影响皮肤的渗透性的中性悬浮剂。但是严禁使用有机溶剂或特殊的增溶剂/悬浮剂。
