【求助】求ASTM D5912 D5881两个标准
  • lizhongyuan5
    2010/04/20
国外标准
  • 悬赏金额:10积分状态:已解决
  • 论坛达人,求ASTM D5912 - 96(2004) 和ASTM D5881 - 95(2005)标准,望分享。
    ASTM D5912 - 96(2004) Standard Test Method for (Analytical Procedure) Determining Hydraulic Conductivity of an Unconfined Aquifer by Overdamped Well Response to Instantaneous Change in Head (Slug)
    ASTM D5881 - 95(2005) Standard Test Method for (Analytical Procedure) Determining Transmissivity of Confined Nonleaky Aquifers by Critically Damped Well Response to Instantaneous Change in Head (Slug)
仙豆 2010/04/21
[quote]原文由 [b]lizhongyuan5(lizhongyuan5)[/b] 发表: 论坛达人,求ASTM D5912 - 96(2004) 和ASTM D5881 - 95(2005)标准,望分享。 ASTM D5912 - 96(2004) Standard Test Method for (Analytical Procedure) Determining Hydraulic Conductivity of an Unconfined Aquifer by Overdamped Well Response to Instantaneous Change in Head (Slug) ASTM D5881 - 95(2005) Standard Test Method for (Analytical Procedure) Determining Transmissivity of Confined Nonleaky Aquifers by Critically Damped Well Response to Instantaneous Change in Head (Slug)[/quote]
  • 仙豆
    第1楼2010/04/21
    lizhongyuan5(lizhongyuan5) 发表:论坛达人,求ASTM D5912 - 96(2004) 和ASTM D5881 - 95(2005)标准,望分享。
  • 仙豆
    第2楼2010/04/21
