savedown
第3楼2010/11/11
用得到那么新的功能吗?
以下是比8.1多出来的功能
3D Vector
3D Error Bars
Contour or 3D Plot from Worksheet Data (Virtual Matrix)
Stock Charts: OHLC & Japanese Candlestick
Custom Label Support for Bar/Column Charts
Transparency and Gradient Fill Control for Graph Objects
Non-Linear Z-axis and Y- and Z-Value Color Map Support for Waterfall Plots
Ternary Plot with Flexible Scale
Apply Color Map to a Mtrix Using Z-Values from Another Matrix
In-Plane Axis Titles and Tick Labels for 3D Graphs
Multiple Interseting Surfaces in 3D Graphs
Color Scale Object Is Available for Matrix 3D Bar Plot
Skip Points Allowed for Error Bars
Import Data in EDF and BDF formats
Import of Multiple Images in the Same Matrix Sheet
Improved Image Profile Tool
New Gadgets for Graphical Analysis Regional Statistics, Differentiation and Interpolation
New Fitting Function Builder
2D FFT Filter
Pro
Specify Parameter Bounds as a Percentage of the Parameter, for NLSF and Peak Analysis
Improved Peak Analyzer Wizard
Zoom and Pan on Graphs, Worksheets, Matrics and Layouts
Embed and Edit MS-Word, Excel and Equation Objects inside Origin Graphs and Layouts
Customizable Data Information Display Window
Thumbnail and Metadata Support for Matrices
