雾非雾
第2楼2010/12/05
查了日本方法使用小柱的对照,是waters产品Sep-Pak Accell QMA。离子交换柱
上网查了一下:
美国 waters 沃特世 WAT020545 SEP-PAK PLUS ACCELL PLUS QMA 50BX
% Carbon Load:6
Barrel Size:Plus
Chemistry:Accell Plus QMA
Endcap:N/A
Format/Type:Plus
Mass Spec Compatibility:No
Mode:Ion-exchange
Particle Size:37-55 µm
Pore Size:300Å
Sorbent Substrate:Silica
Sorbent Weight:360 mg
Units In Package:50/pkg
Water Wettable:No
pH Range:2 - 8
