heguang
第6楼2011/05/28
要用专门的工具就是MicroSolv的 WindowMaker,全世界的毛细管电泳实验室用的都是这个。
Create perfect windows for Capillary Electrophoresis (CE) or CEC each and every time. The MicroSolv Window Maker™ is designed to generate just the right amount of heat to remove the polyimide cladding from bare fused silica capillaries. Supplied with a heating module that creates a 2mm window; other modules can be ordered separately.
