![](https://img1.17img.cn/ui/bimg/SH100000/APP/bbs/bbs_id3.png)
缩写
RS 代表USP 参考标准
CS 代表比色溶液
TS 代表测试溶液
VS 代表滴定液(标准依据个别专论或USP-NF中所列的试剂、指示剂和溶液部分的说明)
影子(hyheying) 发表:Abbreviations
· RS refers to a USP Reference Standard.
· CS refers to a Colorimetric Solution.
· TS refers to a Test Solution.
· VS refers to a Volumetric Solution that is standardized in accordance with directions given in the individual monograph or in the Reagents, Indicators, and Solutions section of USP–NF.
