I understand now, as I am also a layman of 离子色谱. I do not know what is gel? what is column? why resin bed is used?…… For these problems, it is better to transfer this post to 离子色谱 forum.
原文由 xiaoxin2809(xiaoxin2809) 发表:The gel was packed as a thick slurry into a glass column. The resin bed。。。 先说第一句,我没做过离子色谱,不清楚这是在描述色谱柱的什么? 还有后面的 The resin bed指的是树脂骨架? 谢谢!
