symmacros 2011/07/15
抱歉,一直很忙,才发出,写的也不完整,乱,稍作参考。 [b][url=https://insevent.instrument.com.cn/t/Mp][color=#3333ff]gc[/color][/url]MS Lab [/b] [size=3][b][font=Arial]Instrument Model[/font][font=SimSun]:[/font][font=Arial] Agilent 7890-5975C GS-MS, USA[/font][/b][/size] [size=3][b][font=Arial][url=https://insevent.instrument.com.cn/t/Mp][color=#3333ff]gc[/color][/url]-MS Principal[/font][font=SimSun]:[/font][/b][/size] [size=3][b][font=Arial]Gas Chromatography ([url=https://insevent.instrument.com.cn/t/Mp][color=#3333ff]gc[/color][/url])[/font][font=SimSun]:[/font][/b][font=Arial]The [url=https://insevent.instrument.com.cn/t/Mp][color=#3333ff]gc[/color][/url] technique depends on the fact that a mobile phase (gas) carries a sample of a mixture over a stationary phase (liquid or solid), stationary phase has different absorbability or solubility for each composition in the mixture, each composition moves in different speed in column, the mixture will be separated into individual composition to elute. [/font][/size] [font=Arial][size=3]The complete vaporizable sample is evaporated in an injector, introduced into a carrier gas flow and transferred to a capillary column. There the sample is separated and the single components recorded with an detector. The obtained gas chromatogram is analyzed qualitatively by retention time and quantitatively by peak area. [/size][/font] [size=3][b][font=Arial]Mass Spectrometry (MS)[/font][font=SimSun]:[/font][/b][font=Arial]After the sample injection the components are separated on a capillary column, vaporized in the high vacuum of the mass selective detector, ionized in the ion source and shattered into characteristic fragments. The different ions are separated by deflection in a magnetic field depending to their mass/charge ratio (m/z). The recorded ionic current is proportional to the amount of ions produced and by means of the obtained spectra an identification of every component can be achieved. Mass chromatogram can be used for quantitation.[/font][/size] [b][font=Arial][size=3]Application of [url=https://insevent.instrument.com.cn/t/Mp][color=#3333ff]gc[/color][/url]MS:[/size][/font][/b] [size=3][font=Arial]1 [/font][color=black][font=Arial]Support flavorists with analytical results from analyzing food products, natural ingredients or flavorings to help flavorists to identify[/font][/color][color=black][font=SimSun],[/font][/color][color=black][font=Arial]to create and to match flavors more effectively.[/font][/color][/size] [size=3][color=black][font=Arial]2 Support QC by supplying analytical data of raw material and finished products. Help QC [/font][/color][font=Times New Roman]to solve sophistic problem.[/font][/size] [size=3][color=black][font=Arial]3 Test illegal additives, toxic and hazardous substances (contaminants), such as plasticizer, pesticides[/font][/color][color=black][font=SimSun] [/font][/color][color=black][font=Arial]residues, Melamine, etc.[/font][/color][/size][color=black][font=Arial][/font][/color]
dahua1981 2011/07/14
[align=left][img]https://ng1.17img.cn/bbsfiles/images/2011/07/201107141608_304894_1606903_3.jpg[/img] [color=#000000]Agilent 7890/5975-GC/MSD 仪器介绍: [/color]在[url=https://insevent.instrument.com.cn/t/Mp][color=#3333ff]气相色谱[/color][/url](GC)中,载气携带着样品经过固定相,在[url=https://insevent.instrument.com.cn/t/Mp][color=#3333ff]气相色谱[/color][/url]柱中的固体载体,样品中各组分穿过固定相的速度不同导致了各个组分的分离,大概10-20%的已知化合物可以用[url=https://insevent.instrument.com.cn/t/Mp][color=#3333ff]气相色谱[/color][/url]分析。[url=https://insevent.instrument.com.cn/t/Mp][color=#3333ff]气相色谱[/color][/url]一般分析沸点低于400-450℃的化合物。 本仪器用于复杂样品中微量化合物检测;进样类型:分流/不分流进样、填充柱进样、冷柱头进样、程序升温汽化进样口和挥发性物质分析接口;检测器:质谱检测器(MSD)和火焰离子化检测器(FID);并且提供NIST库进行谱库检索。[/align][align=left][color=#000000]仪器性能:[/color] 1. 微量离子检测(TID)技术,提高复杂样品中微量样品的检测灵敏度和可靠性 2. 整体惰性高温离子源:最高可达350℃,适合高沸点化合物的分析 3. 金石英四极杆增强了性能和可靠性,最高1050u 4. 增益归一化调谐功能提高了数据的可比性 5. 二次离轴离子检测系统,大大降低了噪音水平,提高信噪比 6. 质量轴稳定性:0.1amu/48 hr 7. 最大扫描速度:12500amu/s[/align]
dahua1981
第1楼2011/07/14
仪器介绍:
在气相色谱(GC)中,载气携带着样品经过固定相,在气相色谱柱中的固体载体,样品中各组分穿过固定相的速度不同导致了各个组分的分离,大概10-20%的已知化合物可以用气相色谱分析。气相色谱一般分析沸点低于400-450℃的化合物。
仪器性能:
阿宝
第3楼2011/07/14
这个更像是仪器的宣传资料,不太符合楼主的要求
仪器介绍:
仪器性能:
疯子
第4楼2011/07/14
谢谢你啊,神来之笔,我的写好就上来分享
仪器介绍:
仪器性能:
疯子
第5楼2011/07/14
仪器型号:美国安捷伦7890-5975C
气相色谱原理:气相色谱是利用试样中各组份在气相和固定液液相间的分配系数不同,当汽化后的试样被载气带入色谱柱中运行时,组份就在其中的两相间进行反复多次分配,由于固定相对各组份的吸附或溶解能力不同, 因此各组份在色谱柱中的运行速度就不同,经过一定的柱长后,便彼此分离,按顺序离开色谱柱进入检测器,产生的离子流讯号经放大后,在记录器上描绘出各组份的色谱峰。
质谱原理:质谱分析是一种测量离子荷质比(电荷-质量比)的分析方法,其基本原理 是使试样中各组分在离子源中发生电离,生成不同荷质比的带正电荷的离子,经加速电场的作用,形成离子束,进入质量分析器。在质量分析器中,再利用电场和磁场使发生相反的速度色散,将它们分别聚焦而得到质谱图,从而确定其质量。
GC-MS在本实验室的应用:
1. 为调香师提供可靠的技术参数,从而大大的提高辨香、仿香和创香的效率。
2. 可以为QC原料和产品提供技术数据支持。
3. 可以检测非法添加剂和一些有毒有害物质,如:塑化剂、农残,三聚氰胺等。
我想变成英文的,我这样写你们觉得怎么样,谢谢
symmacros
第9楼2011/07/15
gcMS Lab
Instrument Model: Agilent 7890-5975C GS-MS, USA
gc-MS Principal:
Gas Chromatography (gc):The gc technique depends on the fact that a mobile phase (gas) carries a sample of a mixture over a stationary phase (liquid or solid), stationary phase has different absorbability or solubility for each composition in the mixture, each composition moves in different speed in column, the mixture will be separated into individual composition to elute.
Mass Spectrometry (MS):After the sample injection the components are separated on a capillary column, vaporized in the high vacuum of the mass selective detector, ionized in the ion source and shattered into characteristic fragments. The different ions are separated by deflection in a magnetic field depending to their mass/charge ratio (m/z). The recorded ionic current is proportional to the amount of ions produced and by means of the obtained spectra an identification of every component can be achieved. Mass chromatogram can be used for quantitation.
Application of gcMS:
1 Support flavorists with analytical results from analyzing food products, natural ingredients or flavorings to help flavorists to identify,to create and to match flavors more effectively.
2 Support QC by supplying analytical data of raw material and finished products. Help QC to solve sophistic problem.
3 Test illegal additives, toxic and hazardous substances (contaminants), such as plasticizer, pesticides residues, Melamine, etc.
