Instrument detection limit for ICP | |||||||||
Al167.0 | Al308.2 | Al396.1 | As189.0 | Ba233.5 | Ba455.4 | Ca317.9 | Ca422.6 | Cd228.8 | |
标准偏差S | 0.000307 | 0.00081 | 0.000379 | 0.001376 | 0.000176 | 0.000156 | 0.003484 | 0.00331 | 0.000103 |
0.000964 | 0.002543 | 0.00119 | 0.004321 | 0.000553 | 0.00049 | 0.01094 | 0.010393 | 0.000323 | |
ug/L | 0.96398 | 2.5434 | 1.19006 | 4.32064 | 0.55264 | 0.48984 | 10.93976 | 10.3934 | 0.32342 |
Co228.6 | Cr283.5 | Cu324.7 | Fe238.2 | Fe259.9 | Hg184.9 | K766.4 | k769.8 | Mg279.5 | |
标准偏差S | 0.000145 | 0.000195 | 0.000122 | 0.000167 | 0.000158 | 0.001434 | 0.001399 | 0.0003 | |
0.000455 | 0.000612 | 0.000383 | 0.000524 | 0.000496 | 0 | 0.004503 | 0.004393 | 0.000942 | |
ug/L | 0.4553 | 0.6123 | 0.38308 | 0.52438 | 0.49612 | 0 | 4.50276 | 4.39286 | 0.942 |
Mg285.2 | Mn257.6 | Mo202.0 | Ni221.6 | Pb220.3 | Sb206.8 | Se196.0 | Sn189.9 | Ti334.9 | |
标准偏差S | 0.000313 | 0.000152 | 0.000298 | 0.000161 | 0.000686 | 0.001013 | 0.001922 | 0.000517 | 0.000122 |
0.000983 | 0.000477 | 0.000936 | 0.000506 | 0.002154 | 0.003181 | 0.006035 | 0.001623 | 0.000383 | |
ug/L | 0.98282 | 0.47728 | 0.93572 | 0.50554 | 2.15404 | 3.18082 | 6.03508 | 1.62338 | 0.38308 |
Zn206.2 | Zn213.8 | Zr339.1 | |||||||
标准偏差S | 0.001614 | 0.001545 | 0.000126 | ||||||
0.005068 | 0.004851 | 0.000396 | |||||||
ug/L | 5.06796 | 4.8513 | 0.39564 |
