wfdwfdcn
第3楼2012/03/24
For testing in Aqueous (water) Environments
Polymer standards part numbers
Poly(vinyl alcohol) broad
Order No. Description
PSS-pvo5k Details MSDS nominal MW 5000 Poly(vinyl alcohol) broad PDI: >1.50 Packing size [mg]: 1000
PSS-pvo12k Details MSDS nominal MW 12000 Poly(vinyl alcohol) broad PDI: >1.50 Packing size [mg]: 1000
PSS-pvo30k Details MSDS nominal MW 30000 Poly(vinyl alcohol) broad PDI: >1.50 Packing size [mg]: 1000
PSS-pvo40k Details MSDS nominal MW 40000 Poly(vinyl alcohol) broad PDI: >1.50 Packing size [mg]: 1000
PSS-pvo75k Details MSDS nominal MW 75000 Poly(vinyl alcohol) broad PDI: >1.50 Packing size [mg]: 1000
PSS-pvo100k Details MSDS nominal MW 100000 Poly(vinyl alcohol) broad PDI: >1.50 Packing size [mg]: 1000
PSS-pvo120k Details MSDS nominal MW 120000 Poly(vinyl alcohol) broad PDI: >1.50 Packing size [mg]: 1000
PSS-pvo160k Details MSDS nominal MW 160000 Poly(vinyl alcohol) broad PDI: >1.50 Packing size [mg]: 1000
PSS 高聚物标样
PSS提供一种最全面的高聚物标样选择方式以用于不同的场合:
·使用您所研究的高聚物进行有机相和水相的GPC/SEC柱的校正
·多分散性作为一种重要的变量对产品性能和应用参数的影响
·研究高聚物降解及其机理
·作为分子量和/或共聚规整性的函数的单分散聚合物的物理性能的研究
·实验验证模型计算结果
·研究共混物的相容行为
·研究具有特殊性能的高分子,如嵌段和星形高分子
·功能高分子(有端基标注)作为分子尺度范围的探针分子的研究
Global Chromatography Co., Ltd.
Attn.: Mrs. Rebecca Deng
No.1326 BinHe Rd.,125, SuZhou New Dist.
215011 JiangSu
China
phone: +86-512-68054587
mobile: +86-13646204501
fax: +86-21-50310742
email: info(at)globalchrom.com
www: www.globalchrom.com
苏州环球色谱有限责任公司(Global Chromatography Co., Ltd.)
