may0105
第10楼2012/08/21
看原文解释吧:
It is connected from the cooling sleeve to ground. Its primary purpose is to form a circuit that resonates when coupled in parallel with the capacitance formed by the cone, cooling water sleeve and the polypropylene isolator. If the cone is resonant, arc-over effects from the plasma to the cone are minimized.
