should+动词原形的例句是If you succeeded, everything would be all right.?
好象不一致?
cckx(cckx) 发表:c.表示对将来的假想
句型:条件从句+主句
一般过去时:should+动词原形/were+不定式/would+动词原形/should+ 动词原形
If you should succeed, everything would be all right.
If you were to succeed, everything would be all right.
