【Abstract】 Objective To establish the quality standard of Kangxian Capsules. Methods Radix Sophorae Flavescentis,Radix Paeoniae Rubra were identified by TLC.The content of tetrandrine was determined by HPLC RP.HPLC with diamonsil ODS (250 mm×4.6 mm,5 μm)column was used,The mobile phase was a mixture of methanol-trethylamine solution(3.5 → 500)(80:20)with the flow rate of 0.9 mL·min -1 and detection wavelength at 283 nm. Results TLC could identify Radix Sophorae Flavescentis,Radix Paeoniae Rubra.Tetrandrine... 更多还原 【关键词】 抗纤胶囊; 薄层色谱法; 高效液相色谱法; 粉防己碱; 质量标准; 【Key words】 Kangxian capsule; TLC; HPLC; Tetrandrine; Quality standard;
