Component, CAS # 需要分析的组分 | **Critical, Desired, Not Quantified 关键、所需,不需量化 | Typical concentration (ppm, vol %) 正常的浓度(ppm,vol%) | Minimum concentration (ppm, vol %) 最低的浓度(ppm,vol%) | Maximum concentration (ppm, vol %) 最高的浓度(ppm,vol%) | *Lower Detection Limit (ppm, vol %) 最低检测限(ppm,vol%) |
丙烯酸 | 关键 | 0.5% | 0.1% | 1% | 0.01% |
丙烯醛 | 关键 | 16% | 14% | 18% | 0.01% |
丙烯酸 | 关键 | 16% | 14% | 18% | 0.01% |
丙烯醛 | 关键 | 0.3% | 0.01% | 1% | 0.01% |
