雾化压力160KPa | ||||
项目 | 净强度 | 背景 | 总强度 | 信噪比 |
5%硝酸 | 12660 | 2027 | 14687 | 6.245 |
14%硝酸 | 11359 | 2078 | 13437 | 5.612 |
25%硝酸 | 11084 | 2042 | 13126 | 5.427 |
雾化压力180KPa | ||||
5%硝酸 | 12256 | 1241 | 13497 | 9.874 |
14%硝酸 | 11327 | 1228 | 12555 | 9.225 |
25%硝酸 | 10847 | 1227 | 12074 | 8.838 |
雾化压力220KPa | ||||
5%硝酸 | 10743 | 775 | 11518 | 13.864 |
14%硝酸 | 9998 | 784 | 10782 | 12.755 |
25%硝酸 | 9557 | 788 | 10345 | 12.132 |
不同的压力 | 160Pa | 180Pa | 220Pa | ||
5%与14%的偏差 | 10.83% | 7.88% | 7.18% | ||
14%与25%的偏差 | 2.45% | 4.33% | 4.51% | ||
5%与25%的偏差 | 13.28% | 12.21% | 11.69% |
仪器 | ICP结果 | AAS结果 |
5%硝酸 | 179PPM | 203PPM |
14%硝酸 | 189PPM | 203PPM |
25%硝酸 | 193PPM | 202PPM |
160KPa(a) | 12660 | 2027 | 14687 | 6.245 |
180KPa(b) | 12256 | 1241 | 13497 | 9.874 |
220KPa(c) | 10743 | 775 | 11518 | 13.864 |
a与b偏差 | 3.24% | 48.10% | 8.44% | -45.03% |
b与c偏差 | 13.16% | 46.23% | 15.82% | -33.62% |
10rmp | ||||
5%硝酸 | 12227 | 2003 | 14230 | 6.102 |
14%硝酸 | 11138 | 1998 | 13136 | 5.575 |
25%硝酸 | 10625 | 2029 | 12654 | 5.237 |
15rmp | ||||
20rmp | ||||
5%硝酸 | 12593 | 2060 | 14653 | 6.112 |
14%硝酸 | 11573 | 2058 | 13631 | 5.622 |
25%硝酸 | 11202 | 2074 | 13276 | 5.4 |
