Filename | Sample Type | Area | ISTD Area | Amount | %Diff |
1ppmA-1 | Unknown Sample | 81237594 | NA | 1.234 | NA |
1ppmA-2 | Unknown Sample | 78036212 | NA | 1.185 | NA |
1ppmA-3 | Unknown Sample | 81271923 | NA | 1.234 | NA |
1ppmA-4 | Unknown Sample | 85938178 | NA | 1.305 | NA |
1ppmA-5 | Unknown Sample | 87686800 | NA | 1.332 | NA |
1ppmA-6 | Unknown Sample | 89344965 | NA | 1.357 | NA |
1ppmA-7 | Unknown Sample | 89105441 | NA | 1.353 | NA |
1ppmA-8 | Unknown Sample | 98920463 | NA | 1.502 | NA |
1ppmA-9 | Unknown Sample | 107448968 | NA | 1.632 | NA |
1ppmA-10 | Unknown Sample | 101983569 | NA | 1.549 | NA |
色谱分析者
第6楼2013/11/26
有,以下是十针溶剂(正己烷)的
Filename | Sample Type | Area | ISTD Area | Amount | %Diff | |
0-1 | Unknown Sample | 111580 | NA | 0.017 | NA | |
0-2 | Unknown Sample | 70990 | NA | 0.011 | NA | |
0-3 | Unknown Sample | 104881 | NA | 0.016 | NA | |
0-4 | Unknown Sample | 129900 | NA | 0.020 | NA | |
0-5 | Unknown Sample | 113881 | NA | 0.017 | NA | |
0-6 | Unknown Sample | 121023 | NA | 0.018 | NA | |
0-7 | Unknown Sample | 140524 | NA | 0.021 | NA | |
0-8 | Unknown Sample | 143861 | NA | 0.022 | NA | |
0-9 | Unknown Sample | 166308 | NA | 0.025 | NA | |
0-10 | Unknown Sample | 165042 | NA | 0.025 | NA |
蓝是那么的天
第13楼2013/11/26
我的意思是楼主在进完10针标液后进一针空白,看下空白是否有数,确认下时候有用系统残留导致的结果增大。从空白重复测试看应该不是因为试剂污染导致的。
