tang566
第4楼2014/05/12
我们以前也是这样操作,但GLOP7410E里,原文给出了分析修正参数,没有说明什么情况下使用分析修正。
现在糊涂了。
2.5.3 Data Analytical Correctionfor Soluble Method 1
2.5.3.1 The analytical results of solublemethod 1 shall be adjusted by subtracting theanalytical correction in Table 1 toobtain an adjusted analytical result.
Note: The data correction is onlyapplied for soluble method 1. It is not applied for totaldigestionmethod and soluble method 2.
2.5.3.2 The sample is deemed tocomply with the requirement of soluble method 1 ifthe adjusted analytical results isless than or equal to the limits for solublemethod 1 listed in QSOP 3600. Seethe following example.
依风1986
第7楼2014/05/12
我没留意这点,我们还没有出现超标的。如果按照之前做法。类似于其它标准都是超标后考虑加校正因子的
