Pipet 2.0 mL of this solution into a freshly conditioned solid phase extraction column containing benzenesulfonic acid strong cation-exchange packing with a sorbent-mass to column volume ratio of 500 mg per 3 mL, or equivalent, and elute into a 5-mL volumetric flask.
