yunmina
第2楼2015/07/01
7.3.3.3 Paper and paper board
If possible obtain a test portion of not less than 100 mg of the paper or paper board. Each test piece shall have at least one dimension of approximately 6 mm when possible (see H.6). The use of pre-prepared reference materials for visual size comparison is recommended.
纸张样品应该裁剪到哪个尺寸?
千层峰
第3楼2015/07/01
see H.6,H.6怎么说呢?
yunmina
第5楼2015/07/01
H.6 Size of test pieces (7.3.3.2, 7.3.3.3, 7.3.3.4) The test pieces should have at least one dimension of approximately 6 mm, but preferable two dimensions. As an example, a paper sheet shall be cut in pieces of approximately 6 by 6 mm. A fish line shall be cut in pieces of approximately 6 mm in length. It shall be practical for the laboratory to prepare these pieces. The aim is to achieve comparable surface areas between laboratories.
这个是H.6的内容
千层峰
第7楼2015/07/01
按我理解,纸张样品要剪成小片,,尺寸尽量保持在6mmx6mm左右
