name | CAS No. | 浓度/ppm | 浓度/ppm | 浓度/ppm | 浓度/ppm | 浓度/ppm | |||||
toluidine | 95-53-4 | 303.3 | 30.33 | 15.165 | 6.066 | 3.033 | |||||
4-dimethylaniline | 95-68-1 | 299.7 | 29.97 | 14.985 | 5.994 | 2.997 | |||||
6-dimethylaniline | 87-62-7 | 303.9 | 30.39 | 15.195 | 6.078 | 3.039 | |||||
anisidine | 90-04-0 | 300.2 | 30.02 | 15.010 | 6.004 | 3.002 | |||||
chloroaniline | 106-47-8 | 305.4 | 30.54 | 15.270 | 6.108 | 3.054 | |||||
methoxy-5-methylaniline | 120-71-8 | 301.2 | 30.12 | 15.060 | 6.024 | 3.012 | |||||
4,5-trimethylaniline | 137-17-7 | 299.7 | 29.97 | 14.985 | 5.994 | 2.997 | |||||
chloro-2-methylaniline | 95-69-2 | 300.5 | 30.05 | 15.025 | 6.010 | 3.005 | |||||
4-diaminotoluene | 95-80-7 | 300.7 | 30.07 | 15.035 | 6.014 | 3.007 | |||||
4-diaminoanisol | 615-05-4 | 299.9 | 29.99 | 14.995 | 5.998 | 2.999 | |||||
naphthylamine | 91-59-8 | 302.0 | 30.20 | 15.100 | 6.040 | 3.020 | |||||
nitro-o-toluidine | 99-55-8 | 300.6 | 30.06 | 15.03 | 6.012 | 3.006 | |||||
aminobiphenyl | 92-67-1 | 301.7 | 30.17 | 15.085 | 6.034 | 3.017 | |||||
phenyllazoaniline | 60-09-3 | 302.9 | 30.29 | 15.145 | 6.058 | 3.029 | |||||
aminophenyl ether | 101-80-4 | 302.1 | 30.21 | 15.105 | 6.042 | 3.021 | |||||
nzidine | 92-87-5 | 303.0 | 30.30 | 15.150 | 6.060 | 3.030 | |||||
4-methylenedianiline | 101-77-9 | 299.1 | 29.91 | 14.955 | 5.982 | 2.991 | |||||
aminoazotoluene | 97-56-3 | 300.2 | 30.02 | 15.010 | 6.004 | 3.002 | |||||
3-dimethy-4,4-diaminodiphenylmethane | 838-88-0 | 299.5 | 29.95 | 14.975 | 5.990 | 2.995 | |||||
tolidine | 119-93-7 | 298.6 | 29.86 | 14.930 | 5.972 | 2.986 | |||||
4-thiodianiline | 139-65-1 | 299.7 | 29.97 | 14.985 | 5.994 | 2.997 | |||||
3-dichlorobenzidine | 91-94-1 | 301.5 | 30.15 | 15.075 | 6.030 | 3.015 | |||||
4-methylene-bis-chloroaninline | 101-14-4 | 297.7 | 29.77 | 14.885 | 5.954 | 2.977 | |||||
3-dimethoxybenzidine | 119-90-4 | 300.3 | 30.03 | 15.015 | 6.006 | 3.003 | |||||
三内标 | D8 10.02 μg/ml; D10 9.96μg/ml; 2,4,5-三氯苯胺 10.06μg/ml。 | ||||||||||
D8 | 9.0180 | 9.5190 | 9.8196 | 9.9198 | |||||||
D10 | 8.9640 | 9.4620 | 9.7608 | 9.8604 | |||||||
2,4,5-三氯苯胺 | 9.0540 | 9.5570 | 9.8588 | 9.9594 |
