【原创】当前欧盟正在酝酿新的豁免要求(征询意见中),请国内相关的企业从速应对方案
RoHS/WEEE指令
  • 从欧盟官方得到讯息,目前正在商讨中的又有新的排除要求,请相关企业从速查看,相关讯息可以自行联系组委会: Ms Stéphanie Zangl at rohs@oeko.de (英文邮件),或者交寄本人代转(可以接受中文):Jerry.zhao@kema-quality.cn
    http://forum.europa.eu.int/Public/irc/env/rohs_6/library?l=/exemption_requests&vm=detailed&sb=Title
    具体协议内容如下:(可至上述网页查看)
    01. Lead used for shielding of x-radiation emissions for CRT. 1
    02. Lead as soldering alloy in high performance communication electronic board and hexavalent chromium (Cr-VI). 2
    03. GemCore 410 EMV. 1
    04. SAVBIT solder. 1
    05. Sn-Pb soldering used in Ground-based Aeronautical Communication Equipment Manufacturing. 1
    06. Transducers used in professional loudspeaker systems, using tin-lead solder. 1
    07. Tin-lead solder in the manufacture of professional audio equipment. 1
    08. Inventory of special ICS having tin-lead solder on/in leads/balls, used in specialist/professional equipment. 2
    09. Crystal Stones within the battery operated watch. 1
    10. EEE used for the broadcast and homeland security sector. 1
    11. AM186ES-V40 - AM79C961AKC containing lead in used in the leads over plating. 2
    12. Cadmium sulphide or cadmium selenide in polymer based thin film transistor. 1
    13. Lead used in the soldering for surface finishing at the electric pole terminal on the electronic parts. 2
    14. Cadmium contained in the cadmium oxide of a thick film ceramic substrate. 2
    15. All electronics assemblies using lead in solder. 5
    16. Lead in electric overblankets for Hot Spot detection. 8
    17. MPC10 used in automatic vending machines to achieve the payment by card. 1
    18. Hexavalent Chrome Cr-VI when used as a passivate. 2
    19. Lead in circuit boards, Intel 80c188/86 EA\XL microprocessors, ADMC300 DSP, NEC uPD7101 DART and Cr6. 1
    20. Component used in the manufacture of electric blankets and heating pads. 1
    21. Request to delete: "Lead as impurity in RIG Faraday rotators used for fibre optic communications systems". 1
    22. Lead in Trimmer Potentiometer sensors. 1
    23. Cadmium in opto-electronic components. 1
  • 蛋蛋
    第1楼2006/11/13
    赵兄: 你现在可是连接中国与欧盟纽带,辛苦了,呵呵!
  • echojwlu
    第3楼2006/11/14
    不好意思,版主说的排除究竟是原有豁免的排除还是新的豁免?因为以前只知道豁免,排除这个字眼有点生。。。
  • pm1011
    第4楼2006/11/14
    版主,这次落在你后面了!@ 佩服
  • echojwlu
    第5楼2006/11/17
    版主指点一下。。。
    echojwlu 发表:不好意思,版主说的排除究竟是原有豁免的排除还是新的豁免?因为以前只知道豁免,排除这个字眼有点生。。。
  • 7693726
    第6楼2006/11/17
    真不知道那些外国老在搞什么
  • 无名
    第7楼2006/11/17
    [green]新的豁免可能
    echojwlu 发表:版主指点一下。。。
  • tclding
    第9楼2006/11/21
    现在豁免到了第几版了?
  • 无名
    第10楼2006/11/21
    2006.10.12
    2006/690-691-692EC
    tclding 发表:现在豁免到了第几版了?
