Matrix | Sulfonated Poly-Styrene Divinyl Benzene Copolymer | |||||
Ionic Form | Lead | |||||
Particle Size (mm) | 10 | 5 | ||||
Cross Linking | 10% | 8% | 5% | 10% | 8% | |
Max. Pressure (psi,75°C) | 1200 | 1000 | 800 | 1100 | 900 | |
Max Temperature (°C) | 85 | |||||
TypicalMobilePhase | Ultra-pure water | |||||
pH Range | 5 - 9 | |||||
Organic Modifiers (Max) | 5% ethanol, or isopropyl alcohol, or 30% acetonitrile | |||||
Methanol, THF, bases, acids, other metal ions | ||||||
Cleaning | Solvent | 20% acetonitrile | ||||
Flow Rate (mL/min) | 0.2 mL/min | |||||
Temperature (°C) | 50 | |||||
Duration (hrs) | 12 | |||||
Regeneration | Mobile Phase | 100 mM Pb(NO3)2 | ||||
Temperature (°C) | 60 | |||||
Duration (hrs) | 16 | |||||
Ship/Storage Solvent | Ultra-pure water |
Carbomix Pb-NP
内径′长度 (mm′mm) | 交联度 | 粒径 | 孔径 | 型号 |
4.6′250 | 5% | 5 μm | NP | 240505-4625 |
7.8′300 | 5% | 5 μm | NP | 240505-7830 |
4.6′250 | 8% | 5 μm | NP | 240508-4625 |
7.8′300 | 8% | 5 μm | NP | 240508-7830 |
4.6′250 | 10% | 5 μm | NP | 240510-4625 |
7.8′300 | 10% | 5 μm | NP | 240510-7830 |
4.6′250 | 5% | 10 μm | NP | 241005-4625 |
7.8′300 | 5% | 10 μm | NP | 241005-7830 |
4.6′250 | 8% | 10 μm | NP | 241008-4625 |
7.8′300 | 8% | 10 μm | NP | 241008-7830 |
4.6′250 | 10% | 10 μm | NP | 241010-4625 |
7.8′300 | 10% | 10 μm | NP | 241010-7830 |
