PAEs
第3楼2017/06/21
目前来说,还未能有关于DHNUP的标准溶液。DHNUP其实是一个混合物,它主要成分为其中的六种化合物,分别为:
3648-20-2 1,2-Benzenedicarboxylic acid, diundecyl ester
68515-44-6 1,2-Benzenedicarboxylic acid, diheptyl ester, branched and linear
68515-45-7 1,2-Benzenedicarboxylic acid, dinonyl ester, branched and linear
111381-89-6 1,2-Benzenedicarboxylic acid, heptyl nonyl ester, branched and linear
111381-90-9 1,2-Benzenedicarboxylic acid, heptyl undecyl ester, branched and linear
111381-91-0 1,2-Benzenedicarboxylic acid, nonyl undecyl ester, branched and linear
一般来说,DHNUP定性判断为:必须C7-C11均有数才可以判定其含有,定量结果一般为C7-C11分别定量的总和。其特征离子为 249,279,293,307,321,149,167,
