happyjyl
第1楼2007/01/24
取本品1.0g溶于25ml水中,振摇,滤过.加1N醋酸2ml,再加入2ml氯化钡试液.
下面一句话的意思我不太理解.因为化学学的不好,我不知道是待测物与氯化钡反应生成的沉淀不得比氯化钡与0.20ml0.020N的硫酸反应生成的沉淀更多还是别的什么.在我看来这是规定了待测物中硫的限度.
wodeseqizi
第5楼2007/01/24
全文:
Acetaminophen
C8H9NO2 151.16
Acetamide, N-(4-hydroxyphenyl)-.
4¢-Hydroxyacetanilide [103-90-2].
» Acetaminophen contains not less than 98.0 percent and not more than 101.0 percent of C8H9NO2, calculated on the anhydrous basis.
Packaging and storage— Preserve in tight, light-resistant containers, and store at controlled room temperature.
USP Reference standards 11— USP Acetaminophen RS.
Identification—
A: Infrared Absorption 197K.
B: Ultraviolet Absorption 197U—
Solution: 5 µg per mL.
Medium: 0.1 N hydrochloric acid in methanol (1 in 100).
C: It responds to the Thin-layer Chromatographic Identification Test 201, a test solution in methanol containing about 1 mg per mL and a solvent system consisting of a mixture of methylene chloride and methanol (4:1) being used.
Melting range 741: between 168 and 172.
Water, Method I 921: not more than 0.5%.
Residue on ignition 281: not more than 0.1%.
Chloride 221— Shake 1.0 g with 25 mL of water, filter, and add 1 mL of 2 N nitric acid and 1 mL of silver nitrate TS: the filtrate shows no more chloride than corresponds to 0.20 mL of 0.020 N hydrochloric acid (0.014%).
Sulfate 221— Shake 1.0 g with 25 mL of water, filter, add 2 mL of 1 N acetic acid, then add 2 mL of barium chloride TS: the mixture shows no more sulfate than corresponds to 0.20 mL of 0.020 N sulfuric acid (0.02%).
Sulfide— Place about 2.5 g in a 50-mL beaker. Add 5 mL of alcohol and 1 mL of 3 N hydrochloric acid. Moisten a piece of lead acetate test paper with water, and fix to the underside of a watch glass. Cover the beaker with the watch glass so that part of the lead acetate paper hangs down near the pouring spout of the beaker. Heat the contents of the beaker on a hot plate just to boiling: no coloration or spotting of the test paper occurs.
Heavy metals, Method II 231: 0.001%.
Free p-aminophenol— Transfer 5.0 g to a 100-mL volumetric flask, and dissolve in about 75 mL of a mixture of equal volumes of methanol and water. Add 5.0 mL of alkaline nitroferricyanide solution (prepared by dissolving 1 g of sodium nitroferricyanide and 1 g of anhydrous sodium carbonate in 100 mL of water), dilute with a mixture of equal volumes of methanol and water to volume, mix, and allow to stand for 30 minutes. Concomitantly determine the absorbances of this solution and of a freshly prepared solution of p-aminophenol, similarly prepared at a concentration of 2.5 µg per mL, using the same quantities of the same reagents, in 1-cm cells, at the maximum at about 710 nm, with a suitable spectrophotometer, using 5.0 mL of alkaline nitroferricyanide solution diluted with a mixture of equal volumes of methanol and water to 100 mL as the blank: the absorbance of the test solution does not exceed that of the standard solution, corresponding to not more than 0.005% of p-aminophenol.
Limit of p-chloroacetanilide— Transfer 1.0 g to a glass-stoppered, 15-mL centrifuge tube, add 5.0 mL of ether, shake by mechanical means for 30 minutes, and centrifuge at 1000 rpm for 15 minutes or until a clean separation is obtained. Apply 200 µL of the supernatant, in 40-µL portions, to obtain a single spot not more than 10 mm in diameter to a suitable thin-layer chromatographic plate (see Chromatography 621) coated with a 0.25-mm layer of chromatographic silica gel mixture. Similarly apply 40 µL of a Standard solution in ether containing 10 µg of p-chloroacetanilide per mL, and allow the spots to dry. Develop the chromatogram in an unsaturated chamber, with a solvent system consisting of a mixture of solvent hexane and acetone (75:25), until the solvent front has moved three-fourths of the length of the plate. Remove the plate from the developing chamber, mark the solvent front, and allow the solvent to evaporate. Locate the spots in the chromatogram by examination under short-wavelength UV light: any spot obtained from the solution under test, at an RF value corresponding to the principal spot from the Standard solution, is not greater in size or intensity than the principal spot obtained from the Standard solution, corresponding to not more than 0.001% of p-chloroacetanilide.
Readily carbonizable substances 271— Dissolve 0.50 g in 5 mL of sulfuric acid TS: the solution has no more color than Matching Fluid A.
Organic volatile impurities, Method V 467: meets the requirements.
Solvent— Use dimethyl sulfoxide.
Residual solvents 467: meets the requirements.
(Official January 1, 2007)
Assay— Dissolve about 120 mg of Acetaminophen, accurately weighed, in 10 mL of methanol in a 500-mL volumetric flask, dilute with water to volume, and mix. Transfer 5.0 mL of this solution to a 100-mL volumetric flask, dilute with water to volume, and mix. Concomitantly determine the absorbances of this solution and of a Standard solution of USP Acetaminophen RS, in the same medium, at a concentration of about 12 µg per mL in 1-cm cells, at the wavelength of maximum absorbance at about 244 nm, with a suitable spectrophotometer, using water as the blank. Calculate the quantity, in mg, of C8H9NO2 in the Acetaminophen taken by the formula:
10C(AU / AS),
in which C is the concentration, in µg per mL, of USP Acetaminophen RS in the Standard solution; and AU and AS are the absorbances of the solution of Acetaminophen and the Standard solution, respectively.
Auxiliary Information— Staff Liaison : Clydewyn M. Anthony, Ph.D., Scientist
Expert Committee : (MDCCA05) Monograph Development-Cough Cold and Analgesics
USP29–NF24 Page 18
Pharmacopeial Forum : Volume No. 31(4) Page 1024
Phone Number : 1-301-816-8139
Ins_25676b79
第7楼2021/02/17
社区2653社区2654社区2655社区2656社区2657社区2658社区2659社区2660社区2661社区2662社区2663社区2664社区2665社区2666社区2667社区2668社区2669社区2670社区2671社区2672社区2673社区2674社区2675社区2676社区2677社区2678社区2679社区2680社区2681社区2682社区2683社区2684社区2685社区2686社区2687社区2688社区2689社区2690社区2691社区2692社区2693社区2694社区2695社区2696社区2697社区2698社区2699社区2700社区2701社区2702社区2703社区2704社区2705社区2706社区2707社区2708社区2709社区2710社区2711社区2712社区2713社区2714社区2715社区2716社区2717社区2718社区2719社区2720社区2721社区2722社区2723社区2724社区2725社区2726社区2727社区2728社区2729社区2730社区2731社区2732
