The most commonly used method for the covalent binding of biomolecules onto 1-D nanostructures is through the diimide-activated amidation of carboxylic acid terminated nanostructures.
The most commonly used method for the covalent binding of biomolecules onto 1-D nanostructures is through the diimide-activated amidation of carboxylic acid terminated nanostructures. 最常用的方法是通过端羧酸基纳米结构的二酰亚胺活化氨基化合物来进行生物分子与1-D纳米结构的共价结合。
happyjyl发表:The most commonly used method for the covalent binding of biomolecules onto 1-D nanostructures is through the diimide-activated amidation of carboxylic acid terminated nanostructures.
quanbaogang发表:The most commonly used method for the covalent binding of biomolecules onto 1-D nanostructures is through the diimide-activated amidation of carboxylic acid terminated nanostructures.
