石化闪蒸仪器 辅助气相色谱进样 汽化液化气丁烷气体(附文件)
  • 13818290242
    2021/02/23
气相色谱(GC)
  • 一.应用范围
    YunTek 超级闪蒸器适用于带压力液体样品进入分析仪器进行分析的前端气化
    以及样品传输。其设计与性能与国内同种产品相比有一定优势。
    YunTek Super VPI is suitable for front-end gasification and sample transfer
    with pressure liquid samples entering the analysis instrument for analysis. Its
    design and performance have certain advantages compared with the same
    kind of domestic products.
    本产品适用于下述分析前的样品处理:
    This product is suitable for sample processing prior to the following analysis:
    1. 各类工业用烯烃中微量一氧化碳、二氧化碳的分析,配合气相色谱仪使用。
    Analysis of trace amounts of carbon monoxide and carbon dioxide in
    various kinds of industrial olefins, used in conjunction with gas
    chromatography.
    2. 液态烃组成分析,配合气相色谱仪使用。
    Analysis of the composition of liquid hydrocarbons, used in conjunction with
    gas chromatography.
    3. 其他组分分析,如烃类中硫化物分析。
    Other component analyses, such as sulphide analysis in hydrocarbons.
    二.仪器特点
    1.本仪器相比一般的液体进样阀更加方便,而且分析结果更加精确。
    This instrument is more convenient than the general liquid sample valve and
    the analysis results are more accurate.
    2.所有液样品均在恒压环境中被汽化和传输,克服了液态样品在气化过程中,由
    于其密度变化而导致的错误,确保了分析谱图出峰良好。
    All liquid samples are vaporized and transmitted in a constant pressure
    environment, which overcomes the errors caused by the change of density in
    the liquid sample during the gasification process, and ensures that the
    analysis spectrum peaks well.
    3.全程传输管线具有可调伴热功能,保证样品不会冷凝。
    The whole transmission pipeline has adjustable thermal function to ensure
    that the sample does not condense.
    4.可以实现液体和气体样品的进样
    Sampling of liquid and gas samples can be achieved
    5.高样品通量
    High sample flux
    6.系统自带吹扫功能,减少交叉污染
    The system has its own cleaning function to reduce cross-contamination
    三.产品优势
    1.全程惰性化管路及惰性化处理过滤器,杜绝腐蚀、吸附。
    The whole process of inert pipeline and inert treatment filter, to prevent
    corrosion, adsorption.
    2.可用于硫化物及氧化物的痕量物质检测。
    Trace substances that can be used for the detection of sulfides and oxides.
    3.具备压力精确控制功能,使每次进样压力一致,保证分析效果。
    Has the pressure accurate control function, makes each sample pressure
    consistent, guarantees the analysis effect.
    4.设计带有用户可调式加热器两个,分别对闪蒸温度 及进样管路进行温度控
    制,实现全程伴热,防止样品气化后二次冷凝。
    Two user-adjustable heaters are designed to control the temperature of
    theflash steam and the feeding pipe respectively, so as to achieve the full
    range of heat and prevent the second condensation after the sample is
    vaporized.
    5.经闪蒸后样品,进行重复进样分析,分析结果相对标准偏差最大控制在 0.5%,
    优于同类国内产品。
    After the flash steam sample, repeated sample analysis, the analysis results
    relative to the standard deviation of the maximum control at 0.5 %, superior
    to the same domestic products
    应用分析
    石化客户样品组分以液态碳四为主,理论上液态样品热水浴气化进样存在挥发不
    完全的问题,挥发性组分的重现性较差(重烃组分重复性很差,甚至大于 50%)。
    实际数据也验证了,客户直接气态进样数据重复性很差,即使用国产品牌闪蒸器,
    由于使用了过大的传输管路,导致样品不能够被完全气化,进而会导致样品分析
    结果的不完整以及其它错误,亦存在重烃组分挥发不充分或二次冷凝的现象。通
    过闪蒸进样的硫化物分析结果谱图中,羰基硫组分峰面积相对标准偏差低于0.5%,保证了分析结果的重复性。证明了 YunTek 闪蒸器对硫化物组分的进果。
  • xiaoheihei
    第1楼2021/02/23
    看上去很不错,对于石化行业,特殊行业,尤其是钝化要求的非常实用,体积也不是很大。
  • PAEs
    第2楼2021/02/23
    有打广告的嫌疑,去掉了联系方式
    第4楼2021/02/23
    体积小巧,很实用。
  • 13818290242
    第5楼2021/03/01
    哈哈!好的,我记得我把联系方式都删除了呀!还有是吗?
    PAEs(v2911392) 发表:有打广告的嫌疑,去掉了联系方式
  • PAEs
    第6楼2021/03/01
    嗯,我已经删除了
    13818290242(Insp_5058d11a) 发表: 哈哈!好的,我记得我把联系方式都删除了呀!还有是吗?
    第7楼2021/03/01
    有色谱图吗?可以分享图谱。
