Prism (棱镜)and Grating (光栅)。
光学视窗显示的是最近峰波的理论与实际棱镜与光栅位置的图示曲线。视窗的左上角也是一个Cap区域,并显示两个容量分布值:其中第一个值用于产生峰波,第二个是检测器的最终容量分布设定值。
没有看原文上下文,只是大体理解,供参考。
pinkgirl 发表:最近看帮助文件,遇到这点问题,不明白其所云,请高手指点讲的是什么?
Note: This window only appears when you are running an AAnalyst 200/400.
About this window
The Optical Position window displays a graphic plot of the theoretical and actual Prism and Grating locations for the last wavelength peaking. In the upper left corner of the window there is also a Cap: field, which displays two Capacitances values: the first value is used for peaking, and the second value is the final Capacitance setting used by the detector.
Prism and Grating 指的是什么?这段是讲什么的?
谢谢。
