闲鹤野云
第1楼2007/06/10
English, no matter in civil or technical fields/ oral and written format,will be a helpful tool for international communications. Once you are the master of this language, you will be confident in yourself and hold a tool for expression of your thoughts.
Join us here to release your working pressure, relax for a while, share your experience in learning and using of English, and help the others be confident in daily work environment.
闲鹤野云
第8楼2007/06/10
No particular restrictions on topics. Possibly, we can start from your feelings the first time when you worked with a foreigner. Back in the late 1980's, I had the chance to do interpretation for an American Professor from Cornell University, not in my field but in Animal Genetics. There were so many new terms that I did not undstand and did not know how to express in Chinese, though my English at that time was not too bad by my own feeling. During translation, at many times that I could not catch the words, and had to ask the professor to repeat. After this experience, I realized that I needed more trainings in English if I wanted to communicate with foreigners more effectively.
